I wonder if some one know how to make web server httpd-fsdata.c since there is no document or Readme file to explain how to generate this file system C code. I modified the SHTML files and want to generate a new httpd-fsdata.c file, but I have no ideal how to. I also went to uIP web site and downloaded uIPv1.0 reference user menu, but it did not mention any thing regarding httpd-fsdata. Please help to provide more information how to process the httpd-fsdata.c file.
Thanks for your replying. But I am not familiar using the perl programming. Could you or someone please provide me a little more details about to launch makefsdata in perl? for example, launch perl and execute makefsdata from webserver directory etc…
1) Make sure you have Perl installed (Google Active Perl or Strawberry Perl if you are using Windows).
2) Open a command prompt and navigate to the directory that contains makefsdata
3) Type “perl makefsdata”.
It will overwrite your fsdata so make sure you have a back up first if it contains something you want to keep.
