m0o3atef wrote on Monday, July 24, 2017:
Hi everyone,
I just want to ask if it’s possible to compile FreeRTOS using arm-linux-gnueabi-gcc on linux shell? If answer is “yes”, then how to do so?
Thnx in advance.
Hi everyone,
Thnx in advance.
heinbali01 wrote on Monday, July 24, 2017:
HI Mohamed,sure it is possible to compile FreeRTOS using arm-linux-gnueabi-gcc on Linux.
Either you use a Makefile which invokes the compiler and type make from the command-line. Or you use Eclipse which will invoke the compiler for you.
Youi can download the compiled versions of the GNU compilers, or you can compile them your self ( which is a bit complicated to do ).
The Eclipse IDE’s are written in Java, and therefor the will run on any platform ( Windows, Linux )
