In the documentation, it is stated that the default (1000hz) tick is higher than normally would be required.
What I notice is, that when i increase the tick count to 1050hz I never get a tick count.
This happens only when there is a task available. When I just start the scheduler, i can get as high as 10.000
without any problem. I get the tick count by using a trace macro on the PIC32.
What is this about? The task that is running is the only task and has nothing in it (except a continuous loop).
But my main question is, what is the best (highest) tick count without (crashing) sooner or later the tick count?
