malacay wrote on Thursday, November 03, 2011:
I will change the Tick_Rate
#define configTICK_RATE_HZ ( ( portTickType ) 100 )
what does this phrase mean? (portTickType)
I will change it to 1024Hz
rtel wrote on Thursday, November 03, 2011:
See the definition of configUSE_16_BIT_TICKS on http://www.freertos.org/a00110.html
Note you cannot use the portTICK_RATE_HZ constant if you set configTICK_RATE_HZ greater than 1000.
