hex file generation
areeg wrote on Friday, January 26, 2018:
Which files do I have to inculde in Eclipse IDE to succesfully generate hex file for a simple code , target hardware ATmega 32 and GCC compiler ?
rtel wrote on Friday, January 26, 2018:
Not sure what you are asking exactly, but if you are using GCC to build
an application and want to convert the output to hex, then the program
you need is objcopy. That will copy from elf to hex to bin, etc and
comes with GCC.
heinbali01 wrote on Saturday, January 27, 2018:
Although your question is not really about FreeRTOS, her some advice:
If you are using an ATmega32, wouldn’t it be handier to use AtmelStudio (AS) and the tools that come with it?
It has an option to create/generate a new project. You will select a CPU-type, and optionally a board, and you will get a “hello world” example. You can either run it in a simulation mode, or by using a JTAG and real hardware.
HEX-files: normally AS works with .ELF files: these contain a lot more information than a .HEX file, which contains pure code only.
Make sure that you download the latest release of AtmelStudio.
There are great support groups for the Atmel products, like avrfreaks.
