monishsp wrote on Tuesday, June 16, 2009:
Hi all,
I wanted to modify makefile so that I have the freertos.out file along with the freertos.bin
Hi all,
Some guidelines on how to obtain the freertos.out file would be really helpful. I need the .out file for debugging purposes for AT91SAM7256 processor. Currently I am using eclipse.
Thanks in advance,
Monish
edwards3 wrote on Tuesday, June 16, 2009:
You need to use the objcopy command that comes with GCC. Take a look at the binutils manual which you will find somewhere on the gnu.org site. Or simply type "arm-none-eabi-objcopy /?" or "arm-elf-gcc /?" depending on the version of gcc being used.
monishsp wrote on Wednesday, June 17, 2009:
Thanks Edwards. I referred the binutils manual in GNU.org but I am still skeptical of the usage considering that I am not an expert. So here is the Makefile.
CC=arm-elf-gcc
OBJCOPY=arm-elf-objcopy
ARCH=arm-elf-ar
CRT0=boot.s
DEBUG=-g
OPTIM=-O0
LDSCRIPT=atmel-rom.ld
# CFLAGS common to both the THUMB and ARM mode builds
CFLAGS=
-I.
-I./drivers
-I./tasks
-I./armlib
-I./armlib/arch/at91
-I./fatfs
-I…/Common/include
-I…/…/Source/include
-I…/…/Source/portable/GCC/ARM7_AT91SAM7S
-Wall
-D SAM7_GCC
-D THUMB_INTERWORK
-mthumb-interwork
-mcpu=arm7tdmi
-T$(LDSCRIPT)
$(DEBUG)
$(OPTIM)
-fomit-frame-pointer
#-Wextra
#-Wstrict-prototypes
#-Wmissing-prototypes
#-Wmissing-declarations
#-Wno-strict-aliasing
#-I./wifi
#-I./wifi/wlan
#-I./wifi/tcpuip
#-I./wifi/tcpuip/dhcp
#-I./wifi/tcpuip/resolv
#-I./wifi/wlan
#-I./wifi/wlan/WhizFi \
THUMB_FLAGS=-mthumb
LINKER_FLAGS=-Xlinker -ofreertos.elf -Xlinker -M -Xlinker -Map=freertos.map
# Source files that can be built to THUMB mode.
FREERTOS_THUMB_SRC=
…/…/Source/tasks.c
…/…/Source/queue.c
…/…/Source/list.c
…/…/Source/portable/GCC/ARM7_AT91SAM7S/port.c
DEMO_APP_THMUB_SRC=
…/…/Source/portable/MemMang/heap_2.c
main.c
drivers/ad8400.c
drivers/ads8341e.c
drivers/wave.c
drivers/common.c
drivers/sd-mmc.c
drivers/spigate.c
tasks/airTasks.c
tasks/recordTasks.c
armlib/rprintf.c
armlib/arch/at91/processor.c
armlib/arch/at91/uart.c
fatfs/ff.c
fatfs/diskio.c
#drivers/spi.c
#armlib/arch/at91/spi.c
#wifi/common.c
#wifi/debug.c
#wifi/flash_opp.c
#wifi/wln_config.c
#wifi/tcpuip/nic.c
#wifi/tcpuip/tcp_config.c
#wifi/tcpuip/uip_arp.c
#wifi/tcpuip/uip_split.c
#wifi/tcpuip/uip.c
#wifi/wlan/WhizFi/wlan
# Source files that must be built to ARM mode.
# Generally, ISRs and the like -MikeG
ARM_SRC=
tasks/pioIsr.c
…/…/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c
Cstartup_SAM7.c
# Define all object files.
ARM_OBJ = $(ARM_SRC:.c=.o)
FREERTOS_THUMB_OBJ = $(FREERTOS_THUMB_SRC:.c=.o)
DEMO_APP_THMUB_OBJ = $(DEMO_APP_THMUB_SRC:.c=.o)
all: freertos.bin freertos.hex
freertos.bin : freertos.elf
$(OBJCOPY) freertos.elf -O binary freertos.bin
freertos.hex : freertos.elf
$(OBJCOPY) freertos.elf -O ihex freertos.hex
freertos.elf : $(ARM_OBJ) $(DEMO_APP_THMUB_OBJ) $(FREERTOS_THUMB_OBJ) $(CRT0) Makefile FreeRTOSConfig.h
$(CC) $(CFLAGS) $(ARM_OBJ) $(DEMO_APP_THMUB_OBJ) $(LWIP_THUMB_OBJ) $(FREERTOS_THUMB_OBJ) -nostartfiles $(CRT0) $(LINKER_FLAGS)
$(DEMO_APP_THMUB_OBJ) : %.o : %.c $(LDSCRIPT) Makefile FreeRTOSConfig.h
$(CC) -c $(THUMB_FLAGS) $(CFLAGS) $< -o $@
$(FREERTOS_THUMB_OBJ) : %.o : %.c $(LDSCRIPT) Makefile FreeRTOSConfig.h
$(ARM_OBJ) : %.o : %.c $(LDSCRIPT) Makefile FreeRTOSConfig.h
$(CC) -c $(CFLAGS) $< -o $@
#clean :
# touch Makefile
# make target called by Eclipse (Project -> Clean …)
clean:
-rm $(ARM_OBJ) $(FREERTOS_THUMB_OBJ) $(DEMO_APP_THMUB_OBJ) freertos.elf freertos.bin freertos.map freertos.hex
# FLASH PROGRAMMING
# Alternate make target for flash programming only
# You must create a special Eclipse make target (program) to run this part of the makefile
# (Project -> Create Make Target… then set the Target Name and Make Target to "program")
# OpenOCD is run in "batch" mode with a special configuration file and a script file containing
# the flash commands. When flash programming completes, OpenOCD terminates.
# Note that the script file of flash commands (script.ocd) is part of the project
# Programmers: Martin Thomas, Joseph M Dupre, James P Lynch
# Modifies: Gabriele Brosulo, 22/08/2007
# specify output filename here (must be *.bin file)
TARGET = freertos.bin
# specify the directory where openocd executable and configuration files reside
OPENOCD_DIR = ‘/usr/local/OpenOCD/src/’
# specify OpenOCD executable (pp is for the wiggler, ftd2xx is for the USB debuggers)
OPENOCD = $(OPENOCD_DIR)openocd
# specify OpenOCD configuration file (pick the one for your device)
OPENOCD_CFG = OpenOCD/at91sam7s256-wiggler-flash-program.cfg
# program the AT91SAM7S256 internal flash memory
program: $(TARGET)
@echo "Flash Programming with OpenOCD…" # display a message on the console
sudo $(OPENOCD) -f $(OPENOCD_CFG) # program the onchip FLASH here
@echo "Flash Programming Finished." # display a message on the console
So is
-freertos.out : freertos.out
-$(OBJCOPY) freertos.elf -O srec freertos.out
The right way to get a .out file in our Makefile?
Thanks,
Monish
