Hello Forum,
I have some experience in microcontroller programming but i want to do RTOS application with my atmega32 microcontroller using IAR C Compiler.I need step by step knowledge for it becoz i never have done a simple application using RTOS.Please help me n one more thing i have no any development evaluation kit like STK500 or else i want to do it without board silly question but its true i have no any knowledge about implementation of RTOS.
Its a long time since I looked at it but I think the existing AVR323 port will run in the AVRStudio simulator. So you can play with it with no hardware. I was using GCC, but see no reason why you could not generate an elf file from IAR and do the same thing.
Thanks for the reply but i m trying it from many days but i m not able to generte .hex file through it.I have a avr programmer by which i can program the atmega32.please guide me how can i generate .hex file.
I’ve compiled freeRTOS using avr-gcc (winavr), but it’s possible to use winavr as embedded compiler in AVRStudio,
and then startet new AVRStudio project using *cof* file (or something like this
