I’m trying to build a V10 demo project. Files from the “common” folder are looking for file freertos.h. I can’t find one, but there is a file freertosconfig.h which appears to have the same content. So was this file renamed?
George
It is part of the kernel, you should not change it. It will need something like -I amazon-freertos/lib/include
FreeRTOSConfig.h is entirely yours: you can configure the properties and behaviour of the kernel in that file.
Make sure that the -I compiler option for all modules point to the same instance of FreeRTOSConfig.h. Otherwise you can get problems that are difficult to understand.
