I am using FreeRTOS on a custom PIC32 based board that looks a lot like an Explorer 16 board. Anyway, when I erase the 3rd page of flash I am getting a _general_exception_handler. I cannot extract from the volumes of microchip data what the cause is. How do I interpret what the ulCause and ulStatus mean? It might be helpful……
Also, how is _general_exception_handler registered as the exception handler? I searched for _general_exception_handler all thru the code and it only appears in main.c. Is _general_exception_handler some kind of compiler/linker reserved function for microchip? Just curious about that part……
The CAUSE register is described in the manual for the MIPS M4K core, not in the PIC32 manual (at least that was the case when I wrote the port). You can download the M4K technical documentation from MIPS directly.
after re-reading, it is not clear what i am doing :( I downloaded the “HID Bootloader…” example from microchip. It appears to work. In my code, I have a loop:
for( temp = 0; temp < (MaxPageToErase); temp++ )
//pFlashTemp = 0x1d000000;
pFlashTemp = pFlash + (temp*FLASH_PAGE_SIZE);
NVMErasePage((void*) pFlashTemp );
USBDeviceTasks(); //Call USBDriverService() periodically to prevent falling off the bus if any SETUP packets should happen to arrive.
the 3rd time thru the loop I get a _general_exception_handler. I wonder if the call to NVMErasePage causes a _general_exception_handler in some kind of asynchronous way so it just so happens the exception occurs, but i continue stepping???
