I have a question regarding using different tool chain in FreeRTOS demo. I have a demo called FreertosLwipExemplo1 that is FreeRTOS + lwIP + Keil + LM3S web server demo. I think the source code was created and compiled by G++. When I compiled it with Keil RVMDK C compiler, I got the compiling error as below.
Actually I am not familiar with C++ or G++, but I believe that initializing a semaphore handler using = NULL is for C++/G++, but did not for the C syntax, so I just commented the these and left the NULL there. The compile is passed now.
I wonder if any suggestion or ideal about my question.
You definitely cannot use C++ code in your C program, if that is what you are asking. Initialize it any way you like, this is just a C question and again not FreeRTOS related.
edwards, while you can’t (in general) use C++ syntax in a C program, FreeRTOS is compatible with C++ (I know, as I use it this way in a project, and Richard has placed the appropriately guarded extern “C” statements in the headers so it works). Note that if ETHRxBinSemaphore is a global, then the language definition (C and C++) defines that it will be zero/NULL initialized automatically.
