if I comment the initialize array like below, it can pass compiling. But I am not sure if this is correct doing.
xSemaphoreHandle ETHRxBinSemaphore ={ /* =*/ NULL };
The file, ETHIsr.c, is in FreeRTOSlwIPExemplo1.tar.bz2 from you, which there 4 line code from 81 - 102. I believe it is originally compiled by GCC in Linux. I just wonder if any one know this syntax of C or GCC. So far everything seems OK to pass the compiling and link except for the " =", which I commented these contents. I tried to build this demo combining with the demo of Cortex_LM3SXXXX_Keil_IRA, because we need to replace uIP with lwIP TCP/IP stack for implementing SNMP agent in our project.
By the way, I post a question yesterday regarding the Luminiary new ARM Cortex-M3 chip, LM3S9B96, if FreeRTOS current Cortex-LM3Sxxxx_Keil_IAR supports it or not? Also I have been informed that the new release StellarisWare, SW-DK-LM3S9B96-5570, has demo project of SafeRtos_demo that is using SafeRTOS. I wonder if SafeRTOS is the similar to FreeRTOS. I means the rtos functionality for both is the same. Also I am interested in what the price of SafeRTOS is if we want to subscribe it.
SafeRTOS is pre-embedded in the LM3S9B96 ROM and can be used for free. The certification evidence can be purchased separately from WITTENSTEIN. See http://www.safertos.com for more information.
