I’m trying to compile a program under FreeRTOS with IAR compiler and if I use C as language all compile without problems, but if I use embedded C++ or extended embedded C++ I obtain always the following errors:
Error[e46]: Undefined external “AT91F_LowLevelInit” referred in ?RESET ( C:\Empresa\
Inicio\Debug\Obj\Cstartup.r79 )
Error[e46]: Undefined external “vTaskSwitchContext” referred in portasm ( C:\Empresa\Inicio\
Debug\Obj\portasm.r79 )
Error[e46]: Undefined external “vTaskIncrementTick” referred in portasm ( C:\Empresa\
Inicio\Debug\Obj\portasm.r79 )
I tought that FreeRTOS supports C++ programming but I’m not sure.
If FreeRTOS supports C++ someone have an example of IAR compiler settings??
Thanks, but I think that you didn`t understand the question.
I don’t use asm code. I have problems with C++ code.
For example, I have depeloped a class for encapsulate the task funcionality, I can compile the project with this class without problems, but when I write code for instance this class in my main function I have errors linking the project.
The errors are the following:
Linking
Error[e46]: Undefined external “xTaskCreate(pdTASK_CODE, signed char const *, unsigned
short, void *, unsigned long, void * *)” referred in ITask ( C:\Empresa\Inicio\Debug\Obj\
ITask.r79 )
Error[e46]: Undefined external “xTaskGetTickCount()” referred in ITask ( C:\Empresa\Inicio\
Debug\Obj\ITask.r79 )
Error[e46]: Undefined external “vTaskDelayUntil(portTickType *, portTickType)” referred in
ITask ( C:\Empresa\Inicio\Debug\Obj\ITask.r79 )
Error[e46]: Undefined external “vTaskDelete(void *)” referred in ITask ( C:\Empresa\Inicio\
Error[e46]: Undefined external “vTaskStartScheduler()” referred in main ( C:\Empresa\Inicio\
Debug\Obj\main.r79 )
While it may not be asm related it still sounds like the same problem. Are you compiling some files as c++ and some as c? If so they will not link. You need to compile it all as c++ (in which case I’m not sure it will work) or declare the c code as extern “c” (in which case it may work depending on what you are doing with the c++ code).
If you are not sure what this answer means then I suggest reading up a bit on mixing c and c++.
Maybe the problem is that the compiler doesn’t see the extern “C” when compiling the OS, but when it compiles the c++ code. Therefore the C++ expects unmangled names, but the OS functions are mangled. Look in your link listing if you can find mangled versions of the OS functions (in case you get a listing even with failed links).
