kotyal wrote on Thursday, October 26, 2017:
can anyone tell how to port FREERTOS+TCP on FREERTOS
febe2 wrote on Thursday, October 26, 2017:
did you see this?
http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_TCP/FreeRTOS_TCP_Porting.html
In gernal I would say: you need a new NetworkInterface.c file and drivers (gmac/ethernet_phy) for your board.
Which controller do you use?
Best Felix
how to port FREERTOS+TCP on intel galileo board
sry I have no experience with this board…
I think you habe to follow the instructions described here: http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_TCP/FreeRTOS_TCP_Porting.html
right now there are only offical ports released for: sam4e, stm32F4, windows simulator and zynq
heinbali01 wrote on Monday, October 30, 2017:
Hi Mananda, do you have enough information to get on with your project?
Porting +TCP consists of these steps:
Configure the PHY, start auto-negotiation, and wait for the Link Status. Check the actual parameters like speed and duplex.
Configure the EMAC, using the obtained parameters ( speeds and duplex ).
Implement the send function xNetworkInterfaceOutput(). You can check if it works by running Wireshark on a nearby laptop.
Implement the reception function. Use xSendEventStructToIPTask() to pass (the ownership of) the network buffers to the IP-task.
Please have a look at existing +TCP drivers. Here is a newer zero-copy driver that you can use as an example.
And if you have questions, you can ask them on this forum.
