Your function xNetworkInterfaceInitialise() will be called at regular intervals until it returns pdPASS. So as long as the interface is not ready (e.g. PHY Link Status low), you return pdFAIL.
Once it has returned pdPASS, two things will happen:
The xNetworkInterfaceOutput() function will be called by the IP-task to have packets sent.
Your driver will poll RX messages and add them to a queue to the IP-task. It should also test the PHY status.
The FreeRTOSV8.2.3 release has a demo for the Xinlix MicroBlaze processor on a Xilinx KC705 FPGA development board. The MicroBlazeKintex7_EthernetLite demo uses the light weight IP stack (“lwIP”) and the Xilinx “emaclite” driver.
I want to use FreeRTOS+TCP instead of lwIP. Is there any chance of using the lwIP “emaclite” driver with FreeRTOS+TCP? Or is the FreeRTOS+TCP driver model so different that the lwIP driver can’t be used, and a new, FreeRTOS+TCP compatible driver must be developed?
Alternately, is there a Xilinx emaclite driver for FreeRTOS+TCP?
In any TCP/IP stack the drivers can be viewed at two levels:
The low level network input and output functions
The functions that interface the low level network input and output
functions with the TCP/IP stack.
The hardest part is getting (1) to work. In this case Xilinx provide
this for you, and it is the Xilinx low level drivers that are used in
the lwIP example.
(2) is just wrapping the low level drivers in a function that has the
prototype and behaviour expected by the TCP/IP stack - which is a lot
simpler than writing and debugging the drivers in the first place. The
prototype of these interface functions is not compatible between lwIP
and FreeRTOS+TCP, but as you don’t need to create the low level input
and output functions, it should not be difficult porting to
FreeRTOS+TCP. Hein has already linked to the porting documentation, and
there are several examples in the FreeRTOS+TCP download.
As always, start with the easiest thing first - don’t try and do
anything cleaver like have a 100% zero copy driver. Just get the code
working in the simplest way possible and only after it is working assess
whether it meets your performance acquirements, and only if it does not
meet your performance requirements adapt the simple working driver into
something more complex.
