tcomins wrote on Wednesday, July 08, 2009:
I’m getting two compiler errors due to the use of semaphores that I can’ t figure out - details below.
I’m compiling for an NXP LPC-2103 ARM7-TDMI micro using:
- FreeRTOS V5.3.0
- Eclipse Ganeymeded V3.4.2
- Zylin Embedded CDT V4.6.1
- YAGARTO
binutils: 2.19.1
gcc: 4.3.3
newlib: 1.17.0
gdb: 6.8.50-20080308-cvs
I’m trying to use semaphores to implement deferred interrupt processing. I have:
- an init function called from main.c that creates the semaphore…
vSemaphoreCreateBinary( xI2CSemaphore );
- an isr wrapper and an isr
- the isr "gives" the semaphore
xSemaphoreGiveFromISR(xI2CSemaphore, &xI2CSemaphoreWokeTask);
- a task "takes" the semaphore
if (xSemaphoreTake(xI2CSemaphore, (portTickType) 1) == pdTRUE) {
I have the init function and the task in a common .c file that includes a global variable definition for the semaphore handle
xSemaphoreHandle xI2CSemaphore = NULL;
The isr wrapper and isr are in another .c file that includes an external global variable reference
extern xSemaphoreHandle xI2CSemaphore;
I get the following errors:
PROJECT/i2cISR.c:16: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘xI2CSemaphore’
PROJECT/i2cISR.c: In function ‘vI2C_ISR’:
PROJECT/i2cISR.c:74: error: ‘xI2CSemaphore’ undeclared (first use in this function)
I’m stuck. Any help is appreciated!
TC
