I see a port for the TI CC3200 Launch Pad, but not the TI CC1310 part. The former is an M4 ARM Cortex while the latter is an M3 ARM Cortex. What port would I start with to get something running quickly on the CC1310? Any description of what has to be done is appreciated. Thanks, Brett
FreeRTOS will run on any Cortex-M part, but you need to ensure you have
the right port layer. If the part is a Cortex-M3 or a Cortex-M4
(without floating point unit) then you need to use the
FreeRTOS/Source/portable/[compiler]/ARM_CM3 port layer. If the part is
a Cortex-M4F (with floating point unit) then you need to use the
FreeRTOS/Source/portable/[compiler]/ARM_CM4F port layer.
