Yes, FreeRTOS will run on any ARM Cortex-M that has enough RAM. RAM is consumed by the stacks allocated to tasks, so that part is application dependent (that is, how many stacks there are and how large each stack needs to be) rather than RTOS dependent. https://www.freertos.org/FAQMem.html
Correct - no porting is required as such - you just need to create the project and include the appropriate source files:
If your part is an M3 or M4 without an FPU then use the FreeRTOS/Source/portable/[compiler]/ARM_CM3 port layer. If the part has an FPU then use the FreeRTOS/Source/portable/[compiler]/ARM_CM4F port layer. M7 can use the M4 port provided it doesn’t have a r0p0 revision core.
One thing to make clear, by ‘No Porting’, it is meant that everything that the FreeRTOS kernel needs is set. It should be noted that the FreeRTOS kernel has no I/O drivers built in (things like serial ports, I2C, SPI, etc). Those are all part of the application, not FreeRTOS, but for good performance need to be written to use the services that FreeRTOS provides. IF there is a demo provided for some system based on that chip, or some chip close enough to it, then you may be able to borrow the code for some device drivers.
