mimmux wrote on Friday, December 16, 2016:
Hi All,
First of all, thanks for your great work!
I’ve recently downloaded FreeRTOS 9.0.0 and tried to run it on a TI CC3200 LaunchPad using GCC
Now, neither the ARM_CM4F nor the ARM_CM4_MPU ports seem to work.
So I had a look at the port ARM_CM4 that is shipped by Texas Instruments in their CC3200 SDK for FreeRTOS 8.0.1, and to my untrained eye it seemed pretty similar to the ARM_CM3 port. And I tried both the old port by TI, and the FreeRTOS 9.0.0 port for ARM_CM3, and they both seem to work on a simple example using tasks and queues.
My questions would be:
- Is it likely that this board becomes directly supported by FreeRTOS?
- Is the approach of using the ARM_CM3 port correct? Or would it be better to use the ARM_CM4 port shipped by TI for FreeRTOS 8.0.1 ?
Thank you very much.
Dom.
