hardware-dev wrote on Wednesday, November 16, 2016:
We are trying to launch an example code “FreeRTOS_Plus_UDP_and_CLI_LPC1830_GCC”, which is located in the latest official zip-file from FreeRtos:
\FreeRTOSv9.0.0\FreeRTOS-Plus\Demo\FreeRTOS_Plus_UDP_and_CLI_LPC1830_GCC
However, we can’t build the project because we get errors.
Has anyone tested this example?
We are using LPCXpresso v8.2.0_647, but we also tried to build the code with another versions of LPCXpresso.
This is the list of errors, which we get:
Description Resource Path Location Type
make: *** [FreeRTOS_UDP_Demo.axf] Error 1 FreeRTOS_UDP_Demo C/C++ Problem
undefined reference to __get_PRIMASK' queue.c /FreeRTOS_UDP_Demo/FreeRTOS_Source line 1630 C/C++ Problem undefined reference to __get_PRIMASK’ trcBase.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 432 C/C++ Problem
undefined reference to __get_PRIMASK' trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 111 C/C++ Problem undefined reference to __get_PRIMASK’ trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 202 C/C++ Problem
undefined reference to __get_PRIMASK' trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 290 C/C++ Problem undefined reference to __get_PRIMASK’ trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 352 C/C++ Problem
undefined reference to __get_PRIMASK' trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 445 C/C++ Problem undefined reference to __get_PRIMASK’ trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 512 C/C++ Problem
undefined reference to __get_PRIMASK' trcUser.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 114 C/C++ Problem undefined reference to __get_PRIMASK’ trcUser.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 161 C/C++ Problem
undefined reference to __set_PRIMASK' queue.c /FreeRTOS_UDP_Demo/FreeRTOS_Source line 1630 C/C++ Problem undefined reference to __set_PRIMASK’ trcBase.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 432 C/C++ Problem
undefined reference to __set_PRIMASK' trcBase.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 438 C/C++ Problem undefined reference to __set_PRIMASK’ trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 111 C/C++ Problem
undefined reference to __set_PRIMASK' trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 128 C/C++ Problem undefined reference to __set_PRIMASK’ trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 202 C/C++ Problem
undefined reference to __set_PRIMASK' trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 249 C/C++ Problem undefined reference to __set_PRIMASK’ trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 290 C/C++ Problem
undefined reference to __set_PRIMASK' trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 312 C/C++ Problem undefined reference to __set_PRIMASK’ trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 352 C/C++ Problem
undefined reference to __set_PRIMASK' trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 373 C/C++ Problem undefined reference to __set_PRIMASK’ trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 445 C/C++ Problem
undefined reference to __set_PRIMASK' trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 464 C/C++ Problem undefined reference to __set_PRIMASK’ trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 512 C/C++ Problem
undefined reference to __set_PRIMASK' trcKernel.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 556 C/C++ Problem undefined reference to __set_PRIMASK’ trcUser.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 114 C/C++ Problem
undefined reference to __set_PRIMASK' trcUser.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 129 C/C++ Problem undefined reference to __set_PRIMASK’ trcUser.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 161 C/C++ Problem
undefined reference to `__set_PRIMASK’ trcUser.c /FreeRTOS_UDP_Demo/ThirdParty/FreeRTOS_Plus_Trace_Recorder line 177 C/C++ Problem
