Is there a port available for ARM1176JZFS? I am asking because of a possible diploma thesis where a FreeRTOS should run on a Raspberry Pi (http://www.raspberrypi.org/). I did not yet find any valuable information on such a possible project.
So, is it possible to run FreeRTOS on this hardware?
I’m sure you will find some ARM11 ports around the web, it is a topic that comes up occasionally, but I consider this to be slightly out of the FreeRTOS target market so there are no official demos.
That said, I would be very interested if you were to create a port to the RaspberryPI, and can create a forum in the FreeRTOS Interactive site for you if you do.
