Hi All,
One of my task have VTaskDelay(10000). So, This Task should run every 10 sec once. And I was enabled idleTask also to do power save.
My Expectation is Whenever The FreeRTOS calling the idle task , It should pass less the 10000 xExpectedIdleTime. But FreeRTOS passing higher value(0xFFF…) to idle task as xExpectedIdleTime.
Instead of do the function in Task, suppose if i create timer for 10000 todo the task. freeRTOS passing less than 10000 as xExpectedIdleTime whenever its calling the idle Task.
I dont know why its not passing valid expected idle time when i am using vTaskDelay in a task. If any have any idea about it, Please tell me.
Thanks and Regards,
S.Surendar
