hirohiro wrote on Thursday, June 06, 2019:
I’m running into an issue where my tasks aren’t being scheduled after a vTaskDelay() call on a system using the tickless idle. When I configure the system timer to run off the external 32kHz oscillator everything works fine, however if I configure it to run off the internal RC vTaskDelay doesn’t seem to return. However, other tasks (without a vTaskDelay) are still running.
I’m fairly new to FreeRTOS and more so to the tickless idle so I’m wondering if there are any caveats to using vTaskDelay with tickless mode. If vTaskDelay is okay to use in this mode, how do I go about debugging this?
Working:
#define configSTIMER_CLOCK_HZ 32768
#define configSTIMER_CLOCK AM_HAL_STIMER_XTAL_32KHZ
Not Working:
#define configSTIMER_CLOCK_HZ 1000
#define configSTIMER_CLOCK AM_HAL_STIMER_LFRC_1KHZ
- Hardware: Ambiq Apollo 3
- IDE/Toolchain: Keil
- FreeRTOS9
