Hi all,
I am using freeRTOS version 9.x.x on Freescale Cortex-M0+ port. I have configured tickless idle and using systick as normal context switch timer and during tickless idle the systick is deactivated and MCU specific 16 bit low-power timer (LPTMR) is activated to wake the MCU and make time adjusments to tick. It is working, but one problem which I heve is that in SuppressTickAndSleep the parameter xExpectedIdleTime is always less then 4, which is very short to put the MCU in LP-Mode. I am using timers with long periods (30 mins) and other my application tasks are blocked on queues waiting for messages. What am I doing wrong? Why the expected idle time is very short in my case?
Thanks in advance for your answers
thanks for your reply. I found the problem. My tasks were blocking on queues with limited delay times (exactly 5 ticks). I have defined these delay times to port max delay and everything seems to be ok now. Thanks for your links. I’ll definitely look through them
