nameofuser1 wrote on Tuesday, September 18, 2018:
I have stucked with integrating FreeRTOS into my libopencm3 project for stm32f205. Finally I reduced the code to the minimal and it still goes to a hardfault.
Here is my main code. Just a task and UART. No interrupts, no queues. Just send and wait. However crash appears. It looks like that crash appears when performing context switch and the symptoms are similar to that of stack overflow. Nevetheless task is provided tish 4k bytes of stack which should be enough for such a simple task. Also I have checked NVIC IPR registers for enabled interrupts - there are no.
#include <string.h>
#include <libopencm3/cm3/scb.h>
#include <libopencm3/stm32/usart.h>
#include <libopencm3/stm32/gpio.h>
#include <libopencm3/stm32/rcc.h>
#include "FreeRTOS.h"
#include "task.h"
void init(void);
static void simple_task(void *p_param)
(void)p_param;
const char *str = "Hello from dummy task\r\n";
for(;;)
for(uint32_t i=0; i<strlen(str); i++)
usart_wait_send_ready(UART5);
usart_send(UART5, str[i]);
vTaskDelay(100);
int main(void)
TaskHandle_t hndl;
init();
if(xTaskCreate(simple_task, "SimpleTask", 1024, NULL, 1, &hndl) != pdPASS)
for(;;);
vTaskStartScheduler();
for(;;);
return 0;
void init(void)
// setup clock
struct rcc_clock_scale clock = rcc_hse_8mhz_3v3[RCC_CLOCK_3V3_120MHZ];
rcc_clock_setup_hse_3v3(&clock);
scb_set_priority_grouping(SCB_AIRCR_PRIGROUP_GROUP16_NOSUB);
rcc_periph_clock_enable(RCC_GPIOA);
rcc_periph_clock_enable(RCC_GPIOB);
rcc_periph_clock_enable(RCC_GPIOC);
/* Configure UART */
gpio_mode_setup(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO12);
gpio_set_output_options(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_25MHZ, GPIO12);
gpio_set_af(GPIOC, GPIO_AF8, GPIO12);
rcc_periph_clock_enable(RCC_UART5);
usart_set_baudrate(UART5, 921600);
usart_set_databits(UART5, 8);
usart_set_parity(UART5, USART_PARITY_NONE);
usart_set_stopbits(UART5, USART_CR2_STOPBITS_1);
usart_set_mode(UART5, USART_MODE_TX);
usart_set_flow_control(UART5, USART_FLOWCONTROL_NONE);
usart_enable(UART5);
FreeRTOS config:
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
/* Ensure stdint is only used by the compiler, and not the assembler. */
#if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
#include <stdint.h>
#define configSUPPORT_STATIC_ALLOCATION 0
#define configSUPPORT_DYNAMIC_ALLOCATION 1
#define configUSE_IDLE_HOOK 1
#define configUSE_TICK_HOOK 1
#define configCPU_CLOCK_HZ ( 120000000 )
#define configTICK_RATE_HZ ((TickType_t)1000)
#define configMAX_PRIORITIES ( 7 )
#define configMINIMAL_STACK_SIZE ((uint16_t)256)
#define configTOTAL_HEAP_SIZE ((size_t)48*1024)
#define configMAX_TASK_NAME_LEN ( 16 )
#define configUSE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 8
#define configUSE_MALLOC_FAILED_HOOK 1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 1
#define configUSE_HEAP_SCHEME 4
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 0
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTaskGetSchedulerState 1
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
/* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 4
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 15
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself. These are generic
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
/* USER CODE BEGIN 1 */
#define configASSERT( x ) if ((x) == 0) {taskDISABLE_INTERRUPTS(); for( ;; );}
/* USER CODE END 1 */
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
standard names. */
#define vPortSVCHandler sv_call_handler
#define xPortPendSVHandler pend_sv_handler
/* IMPORTANT: This define MUST be commented when used with STM32Cube firmware,
to prevent overwriting SysTick_Handler defined within STM32Cube HAL */
#define xPortSysTickHandler sys_tick_handler
/* USER CODE BEGIN Defines */
/* Section where parameter definitions can be added (for instance, to override default ones in FreeRTOS.h) */
/* USER CODE END Defines */
Startup( I don’t know actually where problem can be so I provide it too):
.syntax unified
.text
.global memset_reg
.type memset_reg, STT_FUNC
memset_reg:
// call with the following (note that the arguments are not validated prior to use):
// r0 - address of first word to write (inclusive)
// r1 - address of first word following the address in r0 to NOT write (exclusive)
// r2 - word value to be written
// both addresses in r0 and r1 needs to be divisible by 4!
.L_loop_begin:
str r2, [r0], 4 // store the word in r2 to the address in r0, post-indexed
cmp r0, r1
bne .L_loop_begin
bx lr
.global reset_handler
.type reset_handler, STT_FUNC
reset_handler:
ldr r0, =_ram_start // r0 - point to beginning of SRAM
ldr r1, =_ram_end // r1 - point to byte after the end of SRAM
ldr r2, =0 // r2 - the byte-sized value to be written
bl memset_reg
// copy .data section from flash to SRAM
ldr r0, =_data // dst addr
ldr r1, =_data_loadaddr // src addr
ldr r2, =_data_size // length in bytes
bl memcpy
// enter the application code
bl main
// shutdown if the application code returns
b shutdown
.global shutdown
.type shutdown, STT_FUNC
shutdown:
cpsid f
ldr r0, =0
mov r1, r0
mov r2, r0
mov r3, r0
mov r4, r0
mov r5, r0
mov r6, r0
mov r7, r0
mov r8, r0
mov r9, r0
mov r10, r0
mov r11, r0
mov r12, r0
ldr lr, =0xffffffff
ldr r0, =_ram_start
ldr r1, =_ram_end
// set to value in r2
bl memset_reg
b . // loop forever
.ltorg // dump literal pool (for the ldr ...,=... commands above)
Linker script:
/* STM32F205RG - 1024K Flash, 128K RAM */
MEMORY
rom (rx) : ORIGIN = 0x08000000, LENGTH = 1024K
ram (rwx) : ORIGIN = 0x20000000, LENGTH = 128K
SECTIONS
.confidential (NOLOAD) : {
*(confidential)
ASSERT ((SIZEOF(.confidential) <= 33K), "Error: Confidential section too big!");
} >ram
INCLUDE libopencm3_stm32f2.ld
_ram_start = ORIGIN(ram);
_ram_end = ORIGIN(ram) + LENGTH(ram);
_stack = _ram_end - 8;
_stack_limit = _stack - end;
__stack_chk_guard = _ram_end - 8;
system_millis = _ram_end - 4;
_data_size = SIZEOF(.data);
libopencm3_stm32f2.ld:
/* Generic linker script for STM32 targets using libopencm3. */
/* Memory regions must be defined in the ld script which includes this one. */
/* Enforce emmition of the vector table. */
EXTERN (vector_table)
/* Define the entry point of the output file. */
ENTRY(reset_handler)
/* Define sections. */
SECTIONS
.text : {
*(.vectors) /* Vector table */
*(.text*) /* Program code */
. = ALIGN(4);
*(.rodata*) /* Read-only data */
. = ALIGN(4);
} >rom
/* C++ Static constructors/destructors, also used for __attribute__
* ((constructor)) and the likes */
.preinit_array : {
. = ALIGN(4);
__preinit_array_start = .;
KEEP (*(.preinit_array))
__preinit_array_end = .;
} >rom
.init_array : {
. = ALIGN(4);
__init_array_start = .;
KEEP (*(SORT(.init_array.*)))
KEEP (*(.init_array))
__init_array_end = .;
} >rom
.fini_array : {
. = ALIGN(4);
__fini_array_start = .;
KEEP (*(.fini_array))
KEEP (*(SORT(.fini_array.*)))
__fini_array_end = .;
} >rom
* Another section used by C++ stuff, appears when using newlib with
* 64bit (long long) printf support
.ARM.extab : {
*(.ARM.extab*)
} >rom
.ARM.exidx : {
__exidx_start = .;
*(.ARM.exidx*)
__exidx_end = .;
} >rom
. = ALIGN(4);
_etext = .;
.data : {
_data = .;
*(.data*) /* Read-write initialized data */
. = ALIGN(4);
_edata = .;
} >ram AT >rom
_data_loadaddr = LOADADDR(.data);
.bss : {
*(.bss*) /* Read-write zero initialized data */
*(COMMON)
. = ALIGN(4);
_ebss = .;
} >ram
* The .eh_frame section appears to be used for C++ exception handling.
* You may need to fix this if you're using C++.
/DISCARD/ : { *(.eh_frame) }
. = ALIGN(4);
end = .;
PROVIDE(_stack = ORIGIN(ram) + LENGTH(ram));
