FreeRTOS + libopecm3. The very simple task hardfault.
nameofuser1 wrote on Tuesday, September 18, 2018:
I have stucked with integrating FreeRTOS into my libopencm3 project for stm32f205. Finally I reduced the code to the minimal and it still goes to a hardfault.
Here is my main code. Just a task and UART. No interrupts, no queues. Just send and wait. However crash appears. It looks like that crash appears when performing context switch and the symptoms are similar to that of stack overflow. Nevetheless task is provided tish 4k bytes of stack which should be enough for such a simple task. Also I have checked NVIC IPR registers for enabled interrupts - there are no. On top of that I have tried two different FreeRTOS version: one from the official sourceforge repo and one generate by ST’s Cube.
#include <string.h>
#include <libopencm3/cm3/scb.h>
#include <libopencm3/stm32/usart.h>
#include <libopencm3/stm32/gpio.h>
#include <libopencm3/stm32/rcc.h>
#include "FreeRTOS.h"
#include "task.h"
void init(void);
static void simple_task(void *p_param)
    (void)p_param;
    const char *str = "Hello from dummy task\r\n";
    for(;;)
        for(uint32_t i=0; i<strlen(str); i++)
            usart_wait_send_ready(UART5);
            usart_send(UART5, str[i]);
        vTaskDelay(100);
int main(void)
    TaskHandle_t hndl;
    init();
    if(xTaskCreate(simple_task, "SimpleTask", 1024, NULL, 1, &hndl) != pdPASS)
        for(;;);
    vTaskStartScheduler();
	for(;;);
	return 0;
void init(void)
    // setup clock
    struct rcc_clock_scale clock = rcc_hse_8mhz_3v3[RCC_CLOCK_3V3_120MHZ];
    rcc_clock_setup_hse_3v3(&clock);
    scb_set_priority_grouping(SCB_AIRCR_PRIGROUP_GROUP16_NOSUB);
    rcc_periph_clock_enable(RCC_GPIOA);
    rcc_periph_clock_enable(RCC_GPIOB);
    rcc_periph_clock_enable(RCC_GPIOC);
    /* Configure UART */
    gpio_mode_setup(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO12);
    gpio_set_output_options(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_25MHZ, GPIO12);
    gpio_set_af(GPIOC, GPIO_AF8, GPIO12);
    rcc_periph_clock_enable(RCC_UART5);
    usart_set_baudrate(UART5, 921600);
    usart_set_databits(UART5, 8);
    usart_set_parity(UART5, USART_PARITY_NONE);
    usart_set_stopbits(UART5, USART_CR2_STOPBITS_1);
    usart_set_mode(UART5, USART_MODE_TX);
    usart_set_flow_control(UART5, USART_FLOWCONTROL_NONE);
    usart_enable(UART5);
FreeRTOS config:
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
/* Ensure stdint is only used by the compiler, and not the assembler. */
#if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
    #include <stdint.h>
#define configUSE_PREEMPTION                     1
#define configSUPPORT_STATIC_ALLOCATION          0
#define configSUPPORT_DYNAMIC_ALLOCATION         1
#define configUSE_IDLE_HOOK                      1
#define configUSE_TICK_HOOK                      1
#define configCPU_CLOCK_HZ                       ( 120000000 )
#define configTICK_RATE_HZ                       ((TickType_t)1000)
#define configMAX_PRIORITIES                     ( 7 )
#define configMINIMAL_STACK_SIZE                 ((uint16_t)256)
#define configTOTAL_HEAP_SIZE                    ((size_t)48*1024)
#define configMAX_TASK_NAME_LEN                  ( 16 )
#define configUSE_TRACE_FACILITY                 1
#define configUSE_16_BIT_TICKS                   0
#define configUSE_MUTEXES                        1
#define configQUEUE_REGISTRY_SIZE                8
#define configCHECK_FOR_STACK_OVERFLOW           2
#define configUSE_MALLOC_FAILED_HOOK             1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION  1
#define configUSE_HEAP_SCHEME                    4
/* Co-routine definitions. */
#define configUSE_CO_ROUTINES                    0
#define configMAX_CO_ROUTINE_PRIORITIES          ( 2 )
#define INCLUDE_vTaskPrioritySet            1
#define INCLUDE_uxTaskPriorityGet           1
#define INCLUDE_vTaskDelete                 1
#define INCLUDE_vTaskCleanUpResources       0
#define INCLUDE_vTaskSuspend                1
#define INCLUDE_vTaskDelayUntil             0
#define INCLUDE_vTaskDelay                  1
#define INCLUDE_xTaskGetSchedulerState      1
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
 /* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
 #define configPRIO_BITS         __NVIC_PRIO_BITS
#else
 #define configPRIO_BITS         4
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY   15
routine that makes calls to interrupt safe FreeRTOS API functions.  DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself.  These are generic
#define configKERNEL_INTERRUPT_PRIORITY 		( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 	( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
/* USER CODE BEGIN 1 */
#define configASSERT( x ) if ((x) == 0) {taskDISABLE_INTERRUPTS(); for( ;; );}
/* USER CODE END 1 */
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
standard names. */
#define vPortSVCHandler    sv_call_handler
#define xPortPendSVHandler pend_sv_handler
/* IMPORTANT: This define MUST be commented when used with STM32Cube firmware,
              to prevent overwriting SysTick_Handler defined within STM32Cube HAL */
#define xPortSysTickHandler sys_tick_handler
/* USER CODE BEGIN Defines */
/* Section where parameter definitions can be added (for instance, to override default ones in FreeRTOS.h) */
/* USER CODE END Defines */
Startup( I don’t know actually where problem can be so I provide it too):
  .syntax unified
  .text
  .global memset_reg
  .type memset_reg, STT_FUNC
memset_reg:
  // call with the following (note that the arguments are not validated prior to use):
  // r0 - address of first word to write (inclusive)
  // r1 - address of first word following the address in r0 to NOT write (exclusive)
  // r2 - word value to be written
  // both addresses in r0 and r1 needs to be divisible by 4!
  .L_loop_begin:
    str r2, [r0], 4 // store the word in r2 to the address in r0, post-indexed
    cmp r0, r1
  bne .L_loop_begin
  bx lr
  .global reset_handler
  .type reset_handler, STT_FUNC
reset_handler:
  ldr r0, =_ram_start // r0 - point to beginning of SRAM
  ldr r1, =_ram_end   // r1 - point to byte after the end of SRAM
  ldr r2, =0          // r2 - the byte-sized value to be written
  bl memset_reg
  // copy .data section from flash to SRAM
  ldr r0, =_data          // dst addr
  ldr r1, =_data_loadaddr // src addr
  ldr r2, =_data_size     // length in bytes
  bl memcpy
  // enter the application code
  bl main
  // shutdown if the application code returns
  b shutdown
  .global shutdown
  .type shutdown, STT_FUNC
shutdown:
  cpsid f
  ldr r0, =0
  mov r1, r0
  mov r2, r0
  mov r3, r0
  mov r4, r0
  mov r5, r0
  mov r6, r0
  mov r7, r0
  mov r8, r0
  mov r9, r0
  mov r10, r0
  mov r11, r0
  mov r12, r0
  ldr lr, =0xffffffff
  ldr r0, =_ram_start
  ldr r1, =_ram_end
  // set to value in r2
  bl memset_reg
  b . // loop forever
  .ltorg // dump literal pool (for the ldr ...,=... commands above)
Linker script:
/* STM32F205RG - 1024K Flash, 128K RAM */
MEMORY
	rom (rx) : ORIGIN = 0x08000000, LENGTH = 1024K
	ram (rwx) : ORIGIN = 0x20000000, LENGTH = 128K
SECTIONS
	.confidential (NOLOAD) : {
		*(confidential)
		ASSERT ((SIZEOF(.confidential) <= 33K), "Error: Confidential section too big!");
	} >ram
INCLUDE libopencm3_stm32f2.ld
_ram_start = ORIGIN(ram);
_ram_end = ORIGIN(ram) + LENGTH(ram);
_stack = _ram_end - 8;
_stack_limit = _stack - end;
__stack_chk_guard = _ram_end - 8;
system_millis = _ram_end - 4;
_data_size = SIZEOF(.data);
libopencm3_stm32f2.ld:
/* Generic linker script for STM32 targets using libopencm3. */
/* Memory regions must be defined in the ld script which includes this one. */
/* Enforce emmition of the vector table. */
EXTERN (vector_table)
/* Define the entry point of the output file. */
ENTRY(reset_handler)
/* Define sections. */
SECTIONS
	.text : {
		*(.vectors)	/* Vector table */
		*(.text*)	/* Program code */
		. = ALIGN(4);
		*(.rodata*)	/* Read-only data */
		. = ALIGN(4);
	} >rom
	/* C++ Static constructors/destructors, also used for __attribute__
	 * ((constructor)) and the likes */
	.preinit_array : {
		. = ALIGN(4);
		__preinit_array_start = .;
		KEEP (*(.preinit_array))
		__preinit_array_end = .;
	} >rom
	.init_array : {
		. = ALIGN(4);
		__init_array_start = .;
		KEEP (*(SORT(.init_array.*)))
		KEEP (*(.init_array))
		__init_array_end = .;
	} >rom
	.fini_array : {
		. = ALIGN(4);
		__fini_array_start = .;
		KEEP (*(.fini_array))
		KEEP (*(SORT(.fini_array.*)))
		__fini_array_end = .;
	} >rom
	 * Another section used by C++ stuff, appears when using newlib with
	 * 64bit (long long) printf support
	.ARM.extab : {
		*(.ARM.extab*)
	} >rom
	.ARM.exidx : {
		__exidx_start = .;
		*(.ARM.exidx*)
		__exidx_end = .;
	} >rom
	. = ALIGN(4);
	_etext = .;
	.data : {
		_data = .;
		*(.data*)	/* Read-write initialized data */
		. = ALIGN(4);
		_edata = .;
	} >ram AT >rom
	_data_loadaddr = LOADADDR(.data);
	.bss : {
		*(.bss*)	/* Read-write zero initialized data */
		*(COMMON)
		. = ALIGN(4);
		_ebss = .;
	} >ram
	 * The .eh_frame section appears to be used for C++ exception handling.
	 * You may need to fix this if you're using C++.
	/DISCARD/ : { *(.eh_frame) }
	. = ALIGN(4);
	end = .;
PROVIDE(_stack = ORIGIN(ram) + LENGTH(ram));
rtel wrote on Tuesday, September 18, 2018:
As this is not using interrupts, and will therefore run sequentially, have you tried stepping through the code to see where the hardfault occurs? Do any characters get sent? Does the tick interrupt increase (set a break point on the vTaskIncrementTick() function in FreeRTOS/Source/tasks.c). You can also use the code on this page to determine where the hardfault occurs https://www.freertos.org/Debugging-Hard-Faults-On-Cortex-M-Microcontrollers.html
Thanks for the answer! I have just a minute ago found a problem. The issue is that of enabled stack smashing protector which is enabled by GCC option -fstack-protector-all. It places word on a stack when entering a function and check the value on function return. I don’t know how exactly it caused the fault but disabling it solved all the problems.
