hello,
I’m porting in FreeRTOS a simple application originally written to work bare-metal on the Ultrascale ZCU102. The application writes data to the device and then waits for an interrupt to be raised and handled by a callback function. This application works fine bare-metal, but when used on FreeRTOS the interrupt raised by the device is not catched.
There are some particular aspects to take care to configure interrupts in FreeRTOS?
here is how interrupts are enabled right now:
XScuGic_Config *GicConfig;
Xil_ExceptionInit();
* Initialize the interrupt controller driver so that it is ready to
* use.
GicConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
if (NULL == GicConfig) {
return XST_FAILURE;
Status = XScuGic_CfgInitialize(IntcInstancePtr, GicConfig,
GicConfig->CpuBaseAddress);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
* Connect the interrupt controller interrupt handler to the hardware
* interrupt handling logic in the processor.
Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_IRQ_INT,
(Xil_ExceptionHandler)XScuGic_InterruptHandler,
IntcInstancePtr);
* Connect a device driver handler that will be called when an
* interrupt for the device occurs, the device driver handler performs
* the specific interrupt processing for the device.
Status = XScuGic_Connect(IntcInstancePtr, EmacPsIntrId,
(Xil_InterruptHandler) XEmacPs_IntrHandler,
(void *) EmacPsInstancePtr);
EmacPsUtilErrorTrap
("Unable to connect ISR to interrupt controller");
return XST_FAILURE;
* Enable interrupts from the hardware
XScuGic_Enable(IntcInstancePtr, EmacPsIntrId);
* Enable interrupts in the processor
Xil_ExceptionEnable();
