I’m working with FreeRTOS on a ZYNQ (Zedboard).
I have the problem that my InterruptHandler does not get called after the “enable ap_done interrupt” of my ipcore gets high…
Does anyone have an idea whats wrong?
here my setup:
Code:
/* GIC Interrupt Controller */
XScuGic_Config *pxGICConfig;
BaseType_t xStatus;
XScuGic xInterruptController; /* Interrupt controller instance */
const uint8_t ucRisingEdge = 3;
void FreeRTOS_Counter_Handler( void *pvNotUsed );
static XCounter xCounter;
int main( void )
prvSetupHardware();
xil_printf( "Hello from Freertos+TCP++ example main\r\n" );
xTaskCreate( prvIPCoreTask,
"IPCORE",
configMINIMAL_STACK_SIZE,
NULL,
tskIDLE_PRIORITY + 2,
&xIPCoreTask );
/* Start the RTOS scheduler. */
vTaskStartScheduler();
static void prvIPCoreTask( void *pvParameters )
XCounter_Config *counter_config = XCounter_LookupConfig(XPAR_COUNTER_0_DEVICE_ID);;
xStatus = XCounter_CfgInitialize(&xCounter, counter_config);
configASSERT( xStatus == XST_SUCCESS );
( void ) xStatus;
xPortInstallInterruptHandler(XPAR_FABRIC_COUNTER_0_INTERRUPT_INTR, FreeRTOS_Counter_Handler,( void * ) &xCounter);
XScuGic_SetPriorityTriggerType( &xInterruptController, XPAR_FABRIC_COUNTER_0_INTERRUPT_INTR, configMAX_API_CALL_INTERRUPT_PRIORITY << portPRIORITY_SHIFT, ucRisingEdge );
vPortEnableInterrupt(XPAR_FABRIC_COUNTER_0_INTERRUPT_INTR);
XCounter_InterruptEnable(&xCounter, 0x1);
XCounter_InterruptGlobalEnable(&xCounter);
XCounter_Set_delay_time(&xCounter,1000);
xil_printf( "Before: %d\n", XCounter_InterruptGetStatus(&xCounter));
XCounter_Start(&xCounter);
for( ;; )
xil_printf( "after: %d\n", XCounter_InterruptGetStatus(&xCounter));
vTaskDelay( pdMS_TO_TICKS( DELAY_1_SECOND ) );;
xil_printf( "Counter Event\r\n" );
static void prvSetupHardware( void )
BaseType_t xStatus;
/* Ensure no interrupts execute while the scheduler is in an inconsistent
state. Interrupts are automatically enabled when the scheduler is
started. */
// portDISABLE_INTERRUPTS();
/* Obtain the configuration of the GIC. */
pxGICConfig = XScuGic_LookupConfig( XPAR_SCUGIC_SINGLE_DEVICE_ID );
/* Sanity check the FreeRTOSConfig.h settings are correct for the
hardware. */
configASSERT( pxGICConfig );
configASSERT( pxGICConfig->CpuBaseAddress == ( configINTERRUPT_CONTROLLER_BASE_ADDRESS + configINTERRUPT_CONTROLLER_CPU_INTERFACE_OFFSET ) );
configASSERT( pxGICConfig->DistBaseAddress == configINTERRUPT_CONTROLLER_BASE_ADDRESS );
/* Install a default handler for each GIC interrupt. */
xStatus = XScuGic_CfgInitialize( &xInterruptController, pxGICConfig, pxGICConfig->CpuBaseAddress );
( void ) xStatus; /* Remove compiler warning if configASSERT() is not defined. */
/* The Xilinx projects use a BSP that do not allow the start up code to be
altered easily. Therefore the vector table used by FreeRTOS is defined in
FreeRTOS_asm_vectors.S, which is part of this project. Switch to use the
FreeRTOS vector table. */
vPortInstallFreeRTOSVectorTable();
