interrupts (Zynq)
eve-shadow wrote on Tuesday, September 12, 2017:
I’m new to FreeRTOS and am trying to build an application on a Zynq device. I’m using the board support package and example code built into Xilinx SDK. The example code runs fine, but now I’m trying to integrate interrupts into the system.
What is the recommended way to initialize interrupts? Should I use the built in Xilinx drivers (SCUGIC), or are there FreeRTOS functions I should call to setup interrupts / handler functions?
In the port code (portZynq7000.c), there is a FreeRTOS_SetupTickInterrupt() function implemented which intializes the ScuGic. I have seen suggestions in other posts that this function/file needs to be changed in order to initialize interrupts for your application. To me this doesn’t really make sense though since you shouldn’t need to edit your BSP for each application.
So how should I setup interrupts?
Any thoughts appreciated.
Thanks!!
richard_damon wrote on Tuesday, September 12, 2017:
It has been a bit since I worked on the Zynq, but as I remember, I changed the FreeRTOS_SetupTickInterrrupt()) function to check if the interrupt controller was already initialized, and use the already setup one if it has been. I did use the low level BSP routines to set up the interrupts.
Just because a chip manufacture provides a Port Layer, doesn’t mean it was done well.
Because their routine initializes the control while setting up the tick, which happens in the call to start the FreeRTOS Scheduler, any interrupts setup previously are forgotten, so you need to configure your interrupts after the interrupts system is enabled, which in my mind is too late.
rtel wrote on Tuesday, September 12, 2017:
The following may help:
http://www.freertos.org/Using-FreeRTOS-on-Cortex-A-Embedded-Processors.html
Ok thanks. So in what function should my interrupt handling logic go? FreeRTOS_SetupTickInterrupt()?
I’m just a bit confused about how the system is supposed to be architected since it isn’t really talked about in the freertos reference or tutorial documents. Is there a document that discusses these topics?
Thanks
Did you see the link I just sent?
Yes I checked that out but am still a bit confused. It talks in the “Interrupt handling” section about the vApplicationIRQHandler. So my understanding is that this function is called when an interrupt occurs, then it should be implemented such that it calls the user’s interrupt handler. Is this correct?
If that’s the case, I still need to figure out how to register my function with the Xilinx port’s GIC. This is the portion I’m mostly confused about. I can post some of the Xilinx port code if that would help.
Thanks
Yes.
You can use the Xilinx drivers. The following file has examples of
timer interrupts being enabled. You can see where XScuGic_Connect() is
installed.
https://sourceforge.net/p/freertos/code/HEAD/tree/trunk/FreeRTOS/Demo/CORTEX_A9_Zynq_ZC702/RTOSDemo/src/Full_Demo/IntQueueTimer.c
eve-shadow wrote on Wednesday, September 13, 2017:
For the benefit of anyone else running into this problem:
In the Xilinx FreeRTOS (9.0.1) BSP, there is a file portZynq7000.c. This file contains a global definition of the interrupt controller
XScuGic xInterruptController;
I was able to get interrupts working by declaring in my code:
extern XScuGic xInterruptController;
You need to initialize it using the usual XScuGic_CfgInitialize and then you can connect your interrupt handlers with XScuGic_Connect & XScuGic_Enable before vTaskStartScheduler().
Thanks all for the help.
