FreeRTOS+FAT memory overwrite in FF_WritePartial
I have an old, very used SD card that occasionally fails. When this happens, my I/O Manager’s fnWriteBlocks returns FF_ERR_IOMAN_DRIVER_FATAL_ERROR | FF_ERRFLAG. This often leads to a HardFault. Chasing down this error path, I think I see a problem in FF_WritePartial:
  • pxFile->pucBuffer is allocated in prvAllocFileHandle:
pxFile->pucBuffer = ( uint8_t * ) ffconfigMALLOC( pxIOManager->usSectorSize );
where pxIOManager->usSectorSize is 512.
  • FF_WritePartial is called with ulCount 4096
  • FF_WritePartial does
memcpy( pxFile->pucBuffer + ulRelBlockPos, pucBuffer, ulCount );
which winds up clobbering various things on the heap.
In this scenario, FF_WritePartial() at ff_file.c:2,166 has:
pxFile	FF_FILE *	0x2000c988 <ucHeap+47644>
pxFile@entry	FF_FILE *	0x2000c988 <ucHeap+47644>
	pxIOManager	FF_IOManager_t *	0x2000a5b8 <ucHeap+38476>
	ulFileSize	uint32_t	16384
	ulObjectCluster	uint32_t	113548
	ulChainLength	uint32_t	1
	ulCurrentCluster	uint32_t	0
	ulAddrCurrentCluster	uint32_t	113548
	ulEndOfChain	uint32_t	268435455
	ulFilePointer	uint32_t	16384
	ulDirCluster	uint32_t	106017
	ulValidFlags	uint32_t	0
	pucBuffer	uint8_t *	0x2000c9c8 <ucHeap+47708> ""
	ucState	uint8_t	0 '\0'
	ucMode	uint8_t	26 '\032'
	usDirEntry	uint16_t	83
	pxNext	struct _FF_FILE *	0x0
ulItemLBA	uint32_t	7282794
ulRelBlockPos	uint32_t	0
ulRelBlockPos@entry	uint32_t	0
ulCount	uint32_t	4096
ulCount@entry	uint32_t	4096
It is called from FF_Write() at ff_file.c:2,465 with:
ulBytesLeft	uint32_t	4096
nBytesWritten	uint32_t	0
xError	FF_Error_t	0
ulElementSize	uint32_t	1
ulElementSize@entry	uint32_t	1
which is called from ff_fwrite() at ff_stdio.c:398 with:
xSize	size_t	1
xSize@entry	size_t	1
xItems	size_t	4096
xItems@entry	size_t	4096
The problem is easy to recreate simply by modifying fnWriteBlocks to occasionally return an error.
Hi, thanks for the bug report!
I’ve opened a PR to fix it here: Add missing error check by archigup · Pull Request #68 · FreeRTOS/Lab-Project-FreeRTOS-FAT · GitHub
If the fix works for you, let us know, thanks!
