heinbali01 wrote on Monday, November 13, 2017:
A summary of the changes made in the above 0001-Changes-since-160919.patch for FreeRTOS+FAT.
Note that all changes are intended to be downward compatible.
● FF_FileSize() can only handle sizes up to 2GB because it returns a signed value.
Old : int32_t FF_FileSize( FF_FILE *pxFile )
New : FF_Error_t FF_GetFileSize( FF_FILE *pxFile, uint32_t *pulSize )
The old function is still there.
The function ff_filelength() (in ff_stdio.c) already returned an unsigned value size_t.
It will now also call FF_GetFileSize() to obtain the size.
If it returns 0ul, then stdioGET_ERRNO() can be called to see if there was an error.
● FF_ExtendFile() always immediately called FF_FlushCache() which is sometimes not desirable.
This will now be configurable with ffconfigFILE_EXTEND_FLUSHES_BUFFERS, default defined as 1:
#if( ffconfigFILE_EXTEND_FLUSHES_BUFFERS != 0 )
FF_Error_t xTempError;
xTempError = FF_FlushCache( pxIOManager );
if( FF_isERR( xError ) == pdFALSE )
xError = xTempError;
#endif /* ffconfigFILE_EXTEND_FLUSHES_BUFFERS */
Some users don’t like this automatic flushing of FAT sectors. In stead they want to call FF_FlushCache() them selves, or wait until FF_fclose() is being called, which will call FF_FlushCache().
● FF_Seek() (from ff_file.c) and ff_fseek() (from ff_stdio.c) did not work properly on files larger that 2GB.
The offset parameter of ff_fseek() is a signed 32-bit long:
int ff_fseek( FF_FILE *pxStream, long lOffset, int iWhence )
With this patch :
iWhence = FF_SEEK_SET : lOffset is interpreted as a `uint32_t`
iWhence = FF_SEEK_CUR : lOffset is interpreted as a a signed offset
iWhence = FF_SEEK_END : lOffset must be <= 0
● FF_Partition() : Make sure that ulHiddenSectors is at least 1
● FF_CreateIOManger() would call FF_CreateEvents(), event if pxIOManager equals NULL
When it fails to create a pxIOManager, it should not proceed to create the event group.
● FF_DeleteIOManager() caused a memory leak, the field pxIOManager->xEventGroup was not deleted
● FF_FlushCache() now has a use hook
See comments in ff_ioman.h
Some users want to perform special actions each time when the +FAT data buffers have been flushed to disk.
● FF_Mount() : The field pxPartition->pcVolumeLabel didn’t get zero-terminated
● FF_IncreaseFreeClusters() could get blocked under certain circumstances
It was trying to take a lock that was already taken.
● ff_sys.c completely tested and updated
This module was rewritten and tested with frequent calls to FF_FS_Add(() and FF_FS_Remove() in a random order.
ff_sys.c makes the mapping between the so-called I/O managers and the (virtual) maps where they get mounted.
Hein Tibosch
