Recently, I am studying the FreeRTOS + FAT source code FreeRTOS-Plus-FAT-160919a-MIT.zip.
I have some confusion for the implementation of the function
FF_FlushCache() >
When after flush the write cache buffer, why it’s needed to search for other buffers that used this sector ?
Because if the only method to get buffer is by the function <FF_GetBuffer()>, then the <FF_GetBuffer()> make sure that there is only one buffer corresponds to one sector, there isn’t a possibility that would make more than one buffer to correspond to one sector.
Hi Kevin, you’re right that FF_GetBuffer() is the only function issuing caching buffers.
It is also true that a given sector can either have a READ, or a WRITE buffer.
And finally: a READ buffer can be shared by many, a WRITE sector has temporary exclusive access.
I also think that this if clause never succeeds:
FF_Error_t FF_FlushCache( FF_IOManager_t *pxIOManager )
<snip>
/* Search for other buffers that used this sector, and mark them as modified
So that further requests will result in the new sector being fetched. */
for( xIndex2 = 0; xIndex2 < pxIOManager->usCacheSize; xIndex2++ )
if( ( xIndex != xIndex2 ) &&
( pxIOManager->pxBuffers[ xIndex2 ].ulSector == pxIOManager->pxBuffers[ xIndex ].ulSector ) &&
( pxIOManager->pxBuffers[ xIndex2 ].ucMode == FF_MODE_READ ) )
pxIOManager->pxBuffers[ xIndex2 ].bModified = pdTRUE;
and I think that the code can be removed without getting any side-effects.
Thanks for taking the effort to report this.
The usage for CacheMemory imposed by FF_GetBuffer() is: a Read buffer can be shared by many, a Write sector has temporary exclusive access.
But the function prvGetFromFATBuffers( ) violate this usage which let Write FATBuffers can be shared. and FATBuffers are initially got by FF_GetBuffer().
So could I know why FATBuffers processed in such way ?
FF_Buffer_t *prvGetFromFATBuffers( FF_IOManager_t *pxIOManager, FF_FATBuffers_t *pxFATBuffers, BaseType_t xBufferIndex,
uint32_t ulFATSector, FF_Error_t *pxError, uint8_t ucMode )
<snip>
if(
( pxBuffer->ulSector == ulFATSector ) &&
( ( ( ucMode & FF_MODE_WRITE ) == 0 ) ||
( ( pxBuffer->ucMode & FF_MODE_WRITE ) != 0 ) )
/* Same sector, AND
write-permission is not required OR the buffer has write permission:
it can be reused. */
#if ffconfigFAT_USES_STAT
fatStat.reuseCount[ ( ucMode & FF_MODE_WRITE ) ? 1 : 0 ]++;
#endif /* ffconfigFAT_USES_STAT */
A task that calls prvGetFromFATBuffers() is reading from, and/or writing to the FAT area.
It has a buffer of the type FF_FATBuffers_t, which contains either 1 or 2 cache buffers, depending on whether a shadow FAT must be maintained.
In an earlier version, prvGetFromFATBuffers() did not exists yet, and FF_GetBuffer() was called directly.
It turned out useful to reuse buffers whenever possible. You also see that the usefulness was empirically tested by maintaining statistics ( ffconfigFAT_USES_STAT ).
The rule that I mentioned earlier:
A WRITE buffer can only have a single user
A READ buffer can have multiple users
You can not obtain a WRITE buffer as long as a READ buffer exists ( and has owners )
You can not obtain a READ buffer as long as a WRITE buffer exists ( and has an owner )
prvGetFromFATBuffers() is obeying the rules except one situation: when it is looking for READ access and it finds that it already owns a WRITE buffer for the same sector. That is considered OK. It saves this action:
/* Release the buffer with FF_MODE_WRITE access. */
FF_ReleaseBuffer( pxIOManager, pxBuffer );
/* Get a buffer with READ access. */
pxBuffer = FF_GetBuffer( pxIOManager, ulFATSector, FF_MODE_READ );
The above would be quite costly and have no advantage.
Although this method saves some costly action, but it also bypass the mechanism that around the pxMatchingBuffer->usNumHandles and pxMatchingBuffer->usPersistance. Does it OK?
Does the situation that when it is looking for READ access and it finds that it already owns a WRITE buffer for the same sector can only be appropriate to FATBuffer, or it can be appropriate to all CacheBuffer ?
It does not bypass these rules, it is not a back-door. usNumHandles and usPersistance are maintained by FF_GetBuffer() and FF_ReleaseBuffer.
The only thing special that it can do is the combination of read/write on a WRITE buffer: which is very efficient when updating FAT sectors.
Something about WRITE buffers: when obtaining a buffer in WRITE mode, you can choose to either read the contents of the sector from disk, or have the buffer cleared.
When you write data to an ever growing file, it is useless to read newly allocated sectors: you will overwrite all data. In this situation, the pseudo attribute FF_MODE_WR_ONLY is used:
The FAT functions will typically not use the write-only mode, and always read the FAT sector before updating it.
But even if FF_MODE_WR_ONLY is being used, you may read back what you have just written to a cache buffer.
No your question:
Other functions that access the contents of files and directories, or special sectors can also read from a WRITE buffer.
No, that would violate the rule: “a WRITE buffer has at most one owner”.
It would allow to obtain a WRITE buffer that is already owned by another task.
