I m trying to run a freertos on off chipp RAM using an LPC2212 micro, and i get a problem when activating SWI interrupt by calling (“SVC 0”) in the function vPortYield existing in PortAsm.s file.
the beahviour wich i saw that the PC jump to internal Flash just after this call, and i m sure that i have well configured the VIC to run in the external memory on the Startup.s
Do you successfully have an application that uses SVC 0 running out of RAM, without FreeRTOS? That would help narrow down if this is indeed a FreeRTOS problem, or just a configuration problem. For example, maybe the vector table is not configured correct for RAM execution.
I have an application that runs on On chipp ROM and uses SVC 0 with freeRtos, and when calling SVC 0, i have the software interrupt running so, i call the vPortYieldProcessor for FreeRtos task switching context. in this case i have no problem.
my code to configure the VIC running on the external RAM is :
You may be using the wrong terminology, but the VIC doesn’t control where SWI goes on ARM processors. ARM processors have an exception vector table, of which SWI is one entry and the VIC is another, which is normally at the bottom of memory. Some implementations of the ARM allow you to map different memories into the lower address space to let you change what is in the exception vector table, and some let you map the exception vector table to another address to do this, The fact that SWI jumps to low memory tells me that you haven’t successfully remapped the table to a different address (if it is even possible on your chip, I am not fluent with the LP series). You need to check the documentation for your chip and see what the proper way to replace the exception vector table is, and make sure your startup code is doing this. This is very chip dependent.
thanks and sorry for the wrong terminology,
My exception vector table is mapped on the External RAM (Adress 0x81000000) and is as :
; Area Definition and Entry Point
; Startup Code must be linked first at Address at which it expects to run.
AREA Reset, CODE, READONLY
ARM
Vectors
;// VECTEURS D’INTERRUPTION AU DEMARRAGE DU CODE
LDR PC, =ResetHandler ;0x00: vecteur de reset
B MainExceptionHandler ;0x04: instruction inexistante
B vPortYieldProcessor ;0x08: interruption logicielle
B MainExceptionHandler ;0x0C: erreur chargement instruction
B MainExceptionHandler ;0x10: data abort
NOP ;0x14: inutilise, on y met l’'adresse du handler IRQ
LDR PC, ; Vector from VicVectAddr
VectorEnd
ResetHandler
; All needed Configuratrion
Normally, when calling SVC 0 form vPortYield, we must go to 0x08 Adress of exception vector table (equivalent to the adress 0x81000008 of External RAM) and we execute the vPortYieldProcessor? but the behavior that the PC goes to the adress 0x0000000C of internal flash. What can be the problem?
Are you sure you have told the chip to remap the interrupt vector (you obviously haven’t as it is going to the wrong address). Just declaring the vectors at that address isn’t going to make the CPU do it.
Looking at the Data Sheet for that part, this is controlled by the state of some pins on the CPU, are those configured correctly?
