I have a bootloader for the STM32 working on a program that is run-to-complete. Another node in this project runs FreeRTOS and although it seems I can load the image using the bootloader, it just gets stuck in the SVC_Handler when I try and run it.
If I try and run FreeRTOS at 0x8003000 (which is where the bootloader sticks FreeRTOS rather than 0x8000000) it also doesn’t run.
With my run-to-complete program I was simply able to recompile to be at 0x8003000 and it ran fine. Is the something else I have to do when recompiling for FreeRTOS to run further up in memory please?
FreeRTOS needs three handlers to be installed in the Cortex vector table. When you jump from your bootloader code to the FreeRTOS code, are you remapping the vector table to where ever you have it in your memory map (probably at 0x8003000 as it is normally at 0x00000000).
This is exactly how I do it with the bootloader that works fine with my run-to-complete program that runs on a different pieice of hardware but still with an almost identical STM32 (the one that works is a 64k part, the FreeRTOS one a 128k part). I am wondering whether there’s something extra that is needed with FreeRTOS I’m not aware of.
It is not something I have direct experience of, but this topic comes up from time to time. I recommend entering “bootloader” as a search term into the archive to see what turns up.
Having ploughed through those I can see a lot of no-solves, one or two aha moments without actually explaining what it was and some talking about interrupts being left over from the bootloader being serviced when FreeRTOS starts. I only have one interrupt enabled in the bootloader and that is the UART. There are definitely no interrupts pending before I hit the OS.
When I tyy and run the version of FreeRTOS that is compiled to start at 0x8003000 I get stuck here:
void vPortStartFirstTask( void )
__asm volatile(
" ldr r0, =0xE000ED08 \n" /* Use the NVIC offset register to locate the stack. */
" ldr r0, \n"
" ldr r0, \n"
" msr msp, r0 \n" /* Set the msp back to the start of the stack. */
" svc 0 \n" /* System call to start first task. */
It’s the last line:
svc 0
That jumps off to address 0x00020E which has this to keep jumping back to itself.
E7FE b 0x0800020E
I suspect that maybe there’s something hardcoded in FreeRTOS that is jumping to where it thinks the vector table should be? If that’s the case, it’s probably nothing to do with the bootloader but somethign else in FreeRTOS needs changing when remapped?
svc seems to be something to do with supervisor mode. I must confess I don’t understamd what supervisor mode is.
" msr msp, r0 \n" /* Set the msp back to the start of the stack. /
" svc 0 \n" / System call to start first task. */
It looks like you are using quite an old version of FreeRTOS. The code sequence should be:
"cpsie \n"
The extra line is only required if interrupts are in the wrong state when the function is called - which would not normally happen with a standard reboot power up sequence, but in your case could well happen when you come through the boot loader.
0x00020E
This address looks like it is in your bootloader code, if the application code is starting at 0x8003000. As it is just jumping to itself it sounds like it is a default handler for something, but which handler?
If it is a hard fault handler, then the additional cpsie instruction as above will fix that, but even then it still seems to be using the boot loaders vector table.
If it is the SVC handler, and it is the boot loaders SVC handler, then it looks like the vector table is not remapped as you expect.
If it is the SVC handler, but a default SVC handler for the application, then it looks like the FreeRTOS interrupt handler has not been installed into the applications vector table.
The thing is, this is not the bootloader version that I have found this problem with. This is just normal FreeRTOS - no bootloader involved right now - with the start of code remapped in the linker to start from 0x8003000. I am having a go, not using the bootloader to try and suss out whether it’s something to do with the bootloader or the remapping of FreeRTOS. The fact that is is falling over when I do this, suggests to my simple mind that with FreeRTOS, there’s more to do than simply change the start of code inn the linker to the new address from 0x8000000.
I can do this with my run-to-complete program on the other STM32 based bit of hardware in the project.
That address should read 0x0800020E, not 0x00020E - sorry about that.
When a Cortex-M boots it expects to find the vector table at address 0. The first thing in the vector table is the address of its stack and the second the address of the program entry point. In your current experiment, without the bootloader, presumably you only have one vector table and you are not remapping it, so the second entry in the vector table should point somewhere above 0x8003000.
From previous posts, it looks like the entry point is being hit correctly, because you are getting as far as vPortStartFirstTask(). When the SVC instruction is hit, you say it then starts executing a handler at 0x0800020E, so it also appears to be the case that it is running a handler in the correct address range too - so the vector table at address 0 is causing a jump to an address above 0x8003000. All good so far. Do I have this right now?
So what happens then is the mystery.
Have you determined the function that is actually being executed when it is branching to itself? It is definitely not the FreeRTOS SVC call handler, so again it is either a default handler for the SVC call (in which case the FreeRTOS handler is not installed in the vector table correctly) or it is a fault handler. I think we need to determine which it is, and the map file produced by the linker should be able to tell you (if not just breaking in the debugger and attempting to look at the source code view).
How are you installing the FreeRTOS interrupt vectors into the vector table? There are two methods that can be used, either by modifying the vector table directly, or by mapping the FreeRTOS interrupts to their CMSIS equivalents if you are using a CMSIS compliant vector table.
I hope what is below is what you’re after in regards the vector table.
All I am doing to normal FreeRTOS is going into the xml file that descibes the processor and changing the memory map for flash to start at 0x8003000 and change its length accordingly. I would stress that if I do this for a normal run-to-compete program then everything works fine, both as a standalone program and with the bootloader.
If I look into memory at address zero with the debugger it has:
0x200001A4
0x080001F1
I would have thought all addresses should be above 0x8003000 as that is where everything has been shifted to as a base address.
I’m not sure how the linker will behave if you tell it there is no flash at address 0, because the CPU is hard coded to load the stack address from that address when it boots.
0x200001A4
0x080001F1
0x200001A4 is presumably a RAM address. Address 0 would be expected to hold a RAM address because it is the stack address. Either the linker is still putting the RAM address at address zero, even though you have told it there is no memory there, because the linker knows it has to. Or, the value you are seeing there is just left over from the last time you ran an application from address zero because the flash memory has not been overwritten or cleared.
Are you still remapping the vector table using the CPU vector base register? It is difficult to see how because it would have to boot through the vector before the code that remapped the vector could be set - unless you have a debugger macro that is doing that before the CPU is taken out of reset.
In any case, the vector table you have posted does not show the FreeRTOS interrupt handler having been installed. Looking just at the SVC handler, I would expect to see a function named vPortSVCHandler() being installed, but what is actually installed is SVCHandler(). That might be ok, if you are #define’ing one name to the other and SVCHandler() is declared as a weak symbol, but otherwise it is an error.
If you find the address of SVCHandler in the map file you will probably find it is the address you end up at branching to yourself when you execute the SVC instruction.
As far as I know I’m not telling the processor there’s no flash at address zero. I am not doing any sort of manual remapping at all. The linker is doing it all. I am sure that the issue is not there because with a run-to-complete program, this method works beautifully. I’m probably misunderstanding what you’re saying though.
I have found this in the map file:
.text.vPortSVCHandler
0x08003394 0x20 THUMB Flash Debug/port.o
0x08003394 vPortSVCHandler
Which to me looks fine as it’s above 0x8003000.
As far as I understand, you can map the start of code to be anywhere in the legitimate flash region and the linker just takes care of it. My suspicion is that something in FreeRTOS does some hard coding to point at an area below my new start address. I would stress that this is only a suspicion and I could be talking through my backside! :~)
I would also stress that if this technique didn’t work for a run-to-complete program I would think it’s a problem with my methodology.
Does that make sense or am I talking nonsense?
I am aware that this is taking your valuable time and I am quite happy to pay you to help fix this with some off-line help and then post the solution when we have fixed it. Thanks again.
Presumably it used to start at address 0x8000000, and then again presumably that memory region is mirrored at address 0 when you boot (you would have to look at the memory map for the device you are using in its reference manual).
Which confirms my suspicion that the vector table is not populated with the FreeRTOS interrupt handlers, because is shows that vPortSVCHandler and SVCHandler are not #defined to be the same thing. SVCHandler is the function that is in the vector table, and it shouldn’t be.
You can be assured that is not the case.
Is the run to complete code executing an SVC instruction that has its own bespoke handler though?
Thanks for the offer - but I prefer to keep these threads online so people with the same problems in the future can hopefully get prompts to sort their own issues without having to start their own threads. I think these support forums, over time (and this one has been here a long time!) are an invaluable developer resource. We all struggle with these low level issue from time to time.
Could you please post the code that actually sets up the vector table - that is the source code rather than the linker output? It will be defined in one of the start up files, which could be either a C file or an asm file.
Ah, yes. I didn’t understand about the mirroring at address zero.
No, I have never come across an SVC instruction before this investigation.
I assume this source code is what you’re after for setting up the vector table (this looks quite like a standard Crossworks file to me):
reset_handler: #ifndef __FLASH_BUILD
/* If this is a RAM build, configure vector table offset register to point
to the RAM vector table. */
ldr r0, =0xE000ED08
ldr r1, =_vectors
str r1, #endif
b _start
Hmm. That is curious. The correct vectors do seem to be being installed, but the linker output from your previous post would seem to show the wrong vectors actually in the table.
Could you zip up your entire project (all source files, and project files) in a way that allows me to build it easily (don’t use any absolute paths to source files or include files) and send it to me? You can send it to r dot barry at freertos.org.
I have not yet managed to program the board, but I have found that the code in post 9 is not what I thought it was. It is not the vector table at all. It seems the correct handler is being installed.
When the svc instruction is executed it jumps to address 0x8000100, which according to the map file is not in your program. Trying to execute instructions from that address results in a branch to 0x800018E, which then just branches to itself. Note that 0x800018E is not in the intended defined memory range either. Just to prove the point, I erased all the flash, and tried running it again and, sure enough now it just branches wildly off the planet as far as the CPU is concerned.
I think your problems start with the way you have attempted to move the program, and I believe the correct thing to do is leave the memory map file alone, and edit the section placement file (having first made a local copy in your project).
Look up flash_placement in the Rowley help system. I believe the thing to do is use the project properties section placement macros to move the start of the .text section to 0x8003000. Having said that, I have before just manually edited one. Below is an example (not correct for your application) I created some time ago to generate extra sections for specific placement when using the MPU. [note the privileged_functions sections I added in, and defined its size, there is also a start parameter you can use I think).
I really don’t think that is the answer I’m afraid. I’ve tried changing it and it makes no difference. I went back to an email I had from Michael at Rowley, describing what I’d done when I initially had issues with by run-to-complete program with the bootloader. He said:
You can use the section placement macro “FLASH_START=0x08003000” and this will have the same effect as the memory map change. So Michael was essentially saying said that my way is one method of doing it, the other is FLASH_START=0x08003000
I have searched high and wide and I cannot find anywhere that describes how to use FLASH_START=0x08003000. I’ve found places that say do this:
It seems Michael is making the same suggestion as me - to use the placement macros. Have you actually tried it though?
I just went back to the original, unmodified FreeRTOS demo (as downloaded in the official FreeRTOS zip file), then copied the section placement file into the project file (as per my post above) and made a single edit to move the start of the flash, as:
compiled and downloaded - and it appears to do exactly what you want. main() is above “0x8003000”, and calling SVC jumps to the correct SVC handler, which is also above “0x8003000”, the kernel starts and the tasks seem to be running.
That does, indeed, load and execute from 0x8003000, thanks. The bootloader now seems to be corrupting something, so is not working. That’'ll be a bug in my code I imagine. I’ll report back once it’s going.
