jvgediya wrote on Wednesday, September 27, 2017:
I am using FreeRTOS for my high traffic network application on CM4 without FPU. I am using CM3 port because there is no FPU on CM4.
I have configASSERT defined in FreeRTOS. My controller supports 3 Priority bits and I have defined below priority related macros which should be proper.
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
/* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 4 /* 15 priority levels */
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0x7
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 1
/* Interrupt priorities used by the kernel port layer itself. These are generic
#define configKERNEL_INTERRUPT_PRIORITY (configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS))
#define configMAX_SYSCALL_INTERRUPT_PRIORITY (configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS))
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
#define configASSERT(x) if((x) == 0) {taskDISABLE_INTERRUPTS(); for(;;);}
NVIC_PRIO_BITS is defined as 3. I am setting priority of my interrupt as 3 which is higher(logically lower) than configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY so it should be fine too for using FreeRTOS(ISR) APIs from ISR.
I am using FreeRTOS V9.0.0.
Problem statement:
I am using FreeRTOS queues for commmunication between ISR and Tasks. When i use portYIELD_FROM_ISR() inside ISR, Even if item is posted successfully to the Queue, Task which is blocking on QueueReceive is not getting unblocked. Everything works for sometime but suddenly this issue appears.
I tried stack overflow hooks but it is not hitting and i have provided enough stack for tasks and interrupts.
This issue appears only when i do YIELD from ISR otherwise everything works fine.
Anyone have any idea about the possible issue?
