jsiegel2 wrote on Tuesday, July 01, 2014:
I recently upgraded from FreeRTOS 6.1.1 to FreeRTOS 8.0.1. In FreeRTOS 6.1.1, I had issues with the “invalid literal constant: pool needs to be closer” error, which was solved by applying a “patch” to portRESTORE and portSAVE. When I use the same code in FreeRTOS 8.0.1, the code compiles fine - but I get a prefetch abort.
I’ve never used assembly so I have no clue what’s going on here! Without JTAG, how can I troubleshoot this? Is there an obvious fix?
The patched code is here:
#define portRESTORE_CONTEXT() \
extern volatile void * volatile pxCurrentTCB; \
extern volatile unsigned portLONG ulCriticalNesting; \
asm volatile ( \
/* Set the LR to the task stack. */ \
"LDR R0, 1f /* =pxCurrentTCB */ \n\t" \
"LDR R0, [R0] \n\t" \
"LDR LR, [R0] \n\t" \
/* The critical nesting depth is the first item on the stack. */ \
/* Load it into the ulCriticalNesting variable. */ \
"LDR R0, 2f /* =ulCriticalNesting */ \n\t" \
"LDMFD LR!, {R1} \n\t" \
"STR R1, [R0] \n\t" \
/* Get the SPSR from the stack. */ \
"LDMFD LR!, {R0} \n\t" \
"MSR SPSR, R0 \n\t" \
/* Restore all system mode registers for the task. */ \
"LDMFD LR, {R0-R14}^ \n\t" \
"NOP \n\t" \
/* Restore the return address. */ \
"LDR LR, [LR, #+60] \n\t" \
/* And return - correcting the offset in the LR to obtain the */ \
/* correct address. */ \
"SUBS PC, LR, #4 \n\t" \
/* Place the pool behind the code. This is never reached. */ \
"1: .word pxCurrentTCB \n\t" \
"2: .word ulCriticalNesting \n\t" \
( void ) ulCriticalNesting; \
( void ) pxCurrentTCB; \
#define portSAVE_CONTEXT() \
asm volatile ( \
"b 3f /* skip data */ \n\t" \
"3: \n\t" \
/* Push R0 as we are going to use the register. */ \
"STMDB SP!, {R0} \n\t" \
/* Set R0 to point to the task stack pointer. */ \
"STMDB SP,{SP}^ \n\t" \
"NOP \n\t" \
"SUB SP, SP, #4 \n\t" \
"LDMIA SP!,{R0} \n\t" \
/* Push the return address onto the stack. */ \
"STMDB R0!, {LR} \n\t" \
/* Now we have saved LR we can use it instead of R0. */ \
"MOV LR, R0 \n\t" \
/* Pop R0 so we can save it onto the system mode stack. */ \
"LDMIA SP!, {R0} \n\t" \
/* Push all the system mode registers onto the task stack. */ \
"STMDB LR,{R0-LR}^ \n\t" \
"NOP \n\t" \
"SUB LR, LR, #60 \n\t" \
/* Push the SPSR onto the task stack. */ \
"MRS R0, SPSR \n\t" \
"STMDB LR!, {R0} \n\t" \
"LDR R0, 2b /* =ulCriticalNesting */ \n\t" \
/* Store the new top of stack for the task. */ \
"LDR R0, 1b /* =pxCurrentTCB */ \n\t" \
"STR LR, [R0] \n\t" \
Instead of:
extern volatile uint32_t ulCriticalNesting; \
__asm volatile ( \
"LDR R0, =pxCurrentTCB \n\t" \
"LDR R0, =ulCriticalNesting \n\t" \
"NOP \n\t" \
__asm volatile ( \
"NOP \n\t" \
"MOV LR, R0 \n\t" \
"NOP \n\t" \
