Been running the for the last 2 weeks, so some feedback…
A: Under CCS 6.1.2 it compiled with a single error, complaining about the array of void in FreeRTOS.h.c line 926. Changed void to uint32_t and it worked perfectly.
B: The ability to initialise all tasks from the scheduler start is great, something I have had to do from the idle task with a flag…
C: Is there any way the timer and idle task names can be made configured from FreeRTOSConfig.h. For some specific reasons I use very short, 3 or 4 character, task names as part of a home made trace facility, hence would like to keep these 2 names short as well.
As getting test coverage was a little tricky we have since made some changes to simplify the static allocation functionality. As a heads up, the rc2 code has the following minor changes (this is currently undergoing long term test and will be made available in a zip if the tests have all passed):
The functions that create RTOS objects using static memory allocation have been simplified and will not revert to using dynamic allocation if a buffer is passed into a function as NULL.
Introduced the configSUPPORT_DYNAMIC_ALLOCATION configuration constant to allow a FreeRTOS application to be built without a heap even being being defined. The Win32 example located in the /FreeRTOS/demo/WIN32-MSVC-Static-Allocation-Only is provided as a reference that does not include a FreeRTOS heap.
configSUPPORT_DYNAMIC_ALLOCATION defaults to 1 for backward compatibility.
configSUPPORT_DYNAMIC_ALLOCATION and configSUPPORT_STATIC_ALLOCATION can both be set to 1 at the same time, but cannot both be set to 0 at the same time.
