This question is a tangent from my previous question: Static allocation on RP2040 Pico
I have followed a YouTube tutorial to implement a simple FreeRTOS project on the Raspberry Pi Pico. This works perfectly.
My question is, what steps should I take to convert this from dynamic allocation to static allocation?
My first thought was simply to edit the constants in my FreeRTOSConfig.h file.
#define configSUPPORT_STATIC_ALLOCATION 0
#define configSUPPORT_DYNAMIC_ALLOCATION 1
… and to use xTaskCreateStatic() etc in my code.
However, this doesn’t work, and gives the error:
heap_4.c:51:6: error: #error This file must not be used if configSUPPORT_DYNAMIC_ALLOCATION is 0
But I don’t know how to remove this file from the build. My CMakeLists.txt looks like this:
add_executable(${ProjectName}
main.c
target_include_directories(${ProjectName} PRIVATE
${CMAKE_CURRENT_LIST_DIR}
target_link_libraries(${ProjectName}
pico_stdlib
FreeRTOS-Kernel-Heap4
pico_add_extra_outputs(${ProjectName})
It’s using the library FreeRTOS-Kernel-Heap4, but I don’t know what to replace this with to use Static allocation. Searching through the example code, I can’t find the string FreeRTOS-Kernel-Heap4 anywhere! Where is this defined, and what should I use instead?
rtel
(Richard Barry)
May 1, 2024, 10:48pm
2
If you use static allocation then you don’t need any of the heap implementations, so can you just remove FreeRTOS-Kernel_Heap4?
Hi rtel,
Hmm. I’m not sure how that could work. If I remove that library, then how am I linking in anything to do with FreeRTOS?
OK, let’s try it. Here’s my CMakeLists.txt now. I have just commented out the FreeRTOS-Kernel-Heap4.
main.c
pico_stdlib
#FreeRTOS-Kernel-Heap4
Now, when I build, I get the error: undefined reference to `xTaskCreateStatic’ as expeted.
Surely I need to tell it to either link in a different library, or compile some .c files explicitly.
Wong
(wong)
May 2, 2024, 1:27pm
4
If you want to use a Static allocation, why you :
You should use 1.
Wong,
Apologies. I mis-typed in my question. I meant to say that I set static to 1 and dynamic to 0, like this:
The correct name for the library is FreeRTOS-Kernel when you want to use static allocation.
aggarg
(Gaurav Aggarwal)
May 6, 2024, 7:52am
7
The code you typed here is still wrong. It should be the following:
#define configSUPPORT_STATIC_ALLOCATION 1
#define configSUPPORT_DYNAMIC_ALLOCATION 0
Thank you for sharing your solution!
