system
(system)
June 28, 2016, 8:21am
1
jordiblasi wrote on Tuesday, June 28, 2016 :
I am trying to install the Eclipse platform to compile freertos for an Intel Galileo 2Gen. I just downloaded the port and the Eclipse Neon for C. I have imported the project and added the include folders from the compiler as no libraries where being loaded:
C:\MinGW\lib\gcc\mingw32\4.6.1\include\c++
C:\MinGW\lib\gcc\mingw32\4.6.1\include\c++\mingw32
C:\MinGW\lib\gcc\mingw32\4.6.1\include\c++\backward
C:\MinGW\include
C:\MinGW\lib\gcc\mingw32\4.6.1\include-fixed
I also included the include folders of the port.
xxx\FreeRTOS\Source\include
xxx\FreeRTOS\Demo\Common\include
I have no include errors but I still find that code is reporting this error on the main_blinky.c file:
Symbol ‘portMAX_DELAY’ could not be resolved main_blinky.c /RTOSDemo/Blinky_Demo line 229 Semantic Error
What I am missing?
Thanks
rtel
(Richard Barry)
June 28, 2016, 8:28am
2
rtel wrote on Tuesday, June 28, 2016 :
You need to have the chosen port layer in the include path too. In this
case:
FreeRTOS/Source/portable/GCC/IA32_flat
[you are better off using an elf compiler rather than the coff MingW]
system
(system)
June 28, 2016, 8:57am
3
I am not sure how to check which compiler I am using. I have installed elf and it is in the path, as described in the Build instructions.
I have added:
C:\jordi\IDI\2016_Odsi\01_development\FreeRTOS\Source\portable\GCC\IA32_flat
And the error disapeared but now I am seeing this one:
.space specifies non-absolute value startup.S /RTOSDemo/Support_Files line 126 C/C++ Problem
I also tried adding this folders:
C:\jordi\soft\ghost-i686-elf-tools\lib\gcc\i686-elf\4.8.2\include
C:\jordi\soft\ghost-i686-elf-tools\lib\gcc\i686-elf\4.8.2\include-fixed
And I got these errors on building the project:
no such instruction: 'portfreertos_interrupt_entry' RegTest.S /RTOSDemo/Full_Demo line 319 C/C++ Problem
no such instruction: 'portfreertos_interrupt_exit' RegTest.S /RTOSDemo/Full_Demo line 321 C/C++ Problem
Which should I have included?
Thanks
rtel
(Richard Barry)
June 28, 2016, 9:05am
4
You should not need to add the compiler’s include paths manually.
What happens if you try building the project exactly as it is in the
download, without any edits?
system
(system)
June 28, 2016, 9:12am
5
Just with the FreeRtos includes i get this:
rtel
(Richard Barry)
June 28, 2016, 9:20am
6
Well the line in question is:
gdt: .space GDT_BYTES
where GDT_BYTES is:
#define GDT_ENTRIES 8
#define GDT_ENTRY_SIZE 8
#define GDT_BYTES (GDT_ENTRIES * GDT_ENTRY_SIZE)
so at a guess you could try modifying the line to hard code the
GDT_BYTES value as such:
gdt: .space 64
system
(system)
June 28, 2016, 9:30am
7
That worked. Now the error is gone, but I see new ones:
Description Resource Path Location Type
no such instruction: `portfreertos_interrupt_entry' RegTest.S /RTOSDemo/Full_Demo line 319 C/C++ Problem
no such instruction: `portfreertos_interrupt_exit' RegTest.S /RTOSDemo/Full_Demo line 321 C/C++ Problem
rtel
(Richard Barry)
June 28, 2016, 9:38am
8
It would seem that your compiler is not pre-processing the source files
properly - that would explain the previous error too. As the file has
an upper case .S extension then, as long as you assembly the assembly
file with GCC rather than GAS, the pre-processor should replace the
macro it is complaining about with inline asm code.
system
(system)
June 28, 2016, 9:54am
9
How can I check which compiler I am using? May this mean that I have MinGW running?
rtel
(Richard Barry)
June 28, 2016, 9:57am
10
The first thing to do is look at the output generated by the compiler as
the project builds - you should be able to see the command line. If it
is just “gcc” then you are most likely using MingW. You can of course
rename the MingW installation directory to see if you then get an error
that the project cannot find the compiler.
system
(system)
June 28, 2016, 10:19am
11
I was calling the wrong compiler. I just corrected it but I am still getting the same error. This is the console output:
12:13:06 **** Incremental Build of configuration Debug for project RTOSDemo ****
Info: Internal Builder is used for build
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Full_Demo" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Support_Files" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOS_Labs_160112\\FreeRTOS\\Source\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOSv9.0.0\\FreeRTOS\\Demo\\Common\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -O0 -g3 -Wall -c -fmessage-length=0 -o "Blinky_Demo\\main_blinky.o" "..\\Blinky_Demo\\main_blinky.c"
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Full_Demo" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Support_Files" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOS_Labs_160112\\FreeRTOS\\Source\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOSv9.0.0\\FreeRTOS\\Demo\\Common\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -O0 -g3 -Wall -c -fmessage-length=0 -o "Support_Files\\HPET.o" "..\\Support_Files\\HPET.c"
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Full_Demo" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Support_Files" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOS_Labs_160112\\FreeRTOS\\Source\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOSv9.0.0\\FreeRTOS\\Demo\\Common\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -O0 -g3 -Wall -c -fmessage-length=0 -o "Support_Files\\freestanding_functions.o" "..\\Support_Files\\freestanding_functions.c"
..\Support_Files\freestanding_functions.c:77:2: warning: #warning The functions in this file are very basic, and not optimised. [-Wcpp]
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Full_Demo" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Support_Files" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOS_Labs_160112\\FreeRTOS\\Source\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOSv9.0.0\\FreeRTOS\\Demo\\Common\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -O0 -g3 -Wall -c -fmessage-length=0 -o "Full_Demo\\main_full.o" "..\\Full_Demo\\main_full.c"
i686-elf-as "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -o "Support_Files\\startup.o" "..\\Support_Files\\startup.S"
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Full_Demo" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Support_Files" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOS_Labs_160112\\FreeRTOS\\Source\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOSv9.0.0\\FreeRTOS\\Demo\\Common\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -O0 -g3 -Wall -c -fmessage-length=0 -o "Support_Files\\printf-stdarg.o" "..\\Support_Files\\printf-stdarg.c"
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Full_Demo" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Support_Files" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOS_Labs_160112\\FreeRTOS\\Source\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOSv9.0.0\\FreeRTOS\\Demo\\Common\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -O0 -g3 -Wall -c -fmessage-length=0 -o "Support_Files\\galileo-support.o" "..\\Support_Files\\galileo-support.c"
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Full_Demo" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Support_Files" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOS_Labs_160112\\FreeRTOS\\Source\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOSv9.0.0\\FreeRTOS\\Demo\\Common\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -O0 -g3 -Wall -c -fmessage-length=0 -o "Full_Demo\\IntQueueTimer.o" "..\\Full_Demo\\IntQueueTimer.c"
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Full_Demo" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Support_Files" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOS_Labs_160112\\FreeRTOS\\Source\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOSv9.0.0\\FreeRTOS\\Demo\\Common\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -O0 -g3 -Wall -c -fmessage-length=0 -o main.o "..\\main.c"
..\main.c: In function 'prvDisplayAssertion':
..\main.c:254:2: warning: format '%u' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
printf( "ASSERT: File = %s, Line = %u\n\r", pcFile, ulLine );
i686-elf-as "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -o "Full_Demo\\RegTest.o" "..\\Full_Demo\\RegTest.S"
..\Full_Demo\RegTest.S: Assembler messages:
..\Full_Demo\RegTest.S:319: Error: no such instruction: `portfreertos_interrupt_entry'
..\Full_Demo\RegTest.S:321: Error: no such instruction: `portfreertos_interrupt_exit'
rtel
(Richard Barry)
June 28, 2016, 10:28am
12
I can see from your output that you are assembling using i686-elf-as,
you need to use i686-elf-gcc as per the .c files.
system
(system)
June 28, 2016, 10:47am
13
When changing from as to gcc I get this:
12:34:13 **** Incremental Build of configuration Debug for project RTOSDemo ****
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -o "Support_Files\\startup.o" "..\\Support_Files\\startup.S"
path/ghost-i686-elf-tools/bin/../lib/gcc/i686-elf/4.8.2/../../../../i686-elf/bin/ld.exe: cannot find crt0.o: No such file or directory
path/ghost-i686-elf-tools/bin/../lib/gcc/i686-elf/4.8.2/../../../../i686-elf/bin/ld.exe: cannot find -lc
collect2.exe: error: ld returned 1 exit status
rtel
(Richard Barry)
June 28, 2016, 10:58am
14
So now it looks like it has compiled and assembled the .c and .S files,
but is failing to link.
Again I would ask, what output do you get if you build the project
without any modifications - as it looks like you may have command line
problems.
system
(system)
June 28, 2016, 11:08am
15
The only modifications to the project is adding the following folders to Preferences-C/C++ General/Paths and Symbols/Includes/GNU
C:\jordi\IDI\2016_Odsi\01_development\intel\FreeRTOS_Labs_160112\FreeRTOS\Source\include
C:\jordi\IDI\2016_Odsi\01_development\intel\FreeRTOSv9.0.0\FreeRTOS\Demo\Common\include
And to Assembly:
This is what I see in the console:
13:04:39 **** Incremental Build of configuration Debug for project RTOSDemo ****
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -o "Full_Demo\\RegTest.o" "..\\Full_Demo\\RegTest.S"
PATH/ghost-i686-elf-tools/bin/../lib/gcc/i686-elf/4.8.2/../../../../i686-elf/bin/ld.exe: cannot find crt0.o: No such file or directory
PATH/ghost-i686-elf-tools/bin/../lib/gcc/i686-elf/4.8.2/../../../../i686-elf/bin/ld.exe: cannot find -lc
rtel
(Richard Barry)
June 28, 2016, 11:14am
16
I think the linker should have a ‘no start files’ option and/or ‘no
standard library’ option on the command line, but from the output - the
fact its trying to find crt0.o and the c library - it would appear that
is not the case.
system
(system)
June 28, 2016, 11:34am
17
Do not use standard start files
No startup or defaul libs
Where not marked. Now they are but I get the same result
i686-elf-gcc "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Full_Demo" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo\\Support_Files" "-IC:\\PATH\\eclispe_neon_c\\RTOSDemo" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOS_Labs_160112\\FreeRTOS\\Source\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\intel\\FreeRTOSv9.0.0\\FreeRTOS\\Demo\\Common\\include" "-IC:\\PATH\\2016_Odsi\\01_development\\FreeRTOS\\Source\\portable\\GCC\\IA32_flat" -O0 -g3 -Wall -c -fmessage-length=0 -o "Support_Files\\GPIO_I2C.o" "..\\Support_Files\\GPIO_I2C.c"
c:/PATH/ghost-i686-elf-tools/bin/../lib/gcc/i686-elf/4.8.2/../../../../i686-elf/bin/ld.exe: cannot find crt0.o: No such file or directory
c:/PATH/ghost-i686-elf-tools/bin/../lib/gcc/i686-elf/4.8.2/../../../../i686-elf/bin/ld.exe: cannot find -lc
system
(system)
June 28, 2016, 2:40pm
18
Done it.
Looks like I needed to add the “-nostartfiles -nostdlib” not only to the compile configuration but to the assembler. No It builds without errors.
Thanks
system
(system)
19
Done it.
Thanks
