Hello there
I’m newbie at FreeRTOS, Before getting starts, I’d installed eclipse Kepler, and then gcc 4.9.2 MinGW along with latest version of free RTOS 8.2.1
then after I’ve import FreeRTOS Demo as explained on freertos sight.
now when i building new “Hello world” demo project then it shows me following error
“fatal error: freeRTOS.h: No such file or directory”
can any one help me!
I’ll appreciate all precious comments
here is snap of my setup on eclipse
The header file FreeRTOS.h is part of the FreeRTOS kernel and it is located in:
<FreeRTOS source>\include\FreeRTOS.h
It is included as :
#include "FreeRTOS.h"
so you will have to tell the compiler where to find this header file. Right-click on your project “mahendra” and look for “paths and symbols” or “include directories”.
It must have an entry like <FreeRTOS source>\include where <FreeRTOS source> is some environment variable pointing to a directory in your projec space, or an absolute path.
Hello there
The project should, in theory, be pre-configured. So if it is imported
into Eclipse using the introductions on the website (which you say you
followed) then its curious this error should occur.
Did you change the directory structure at all? The project references
files from outside of its own project directory, so if so try importing
a project from a clean unzip of the FreeRTOS distribution, without any
modifications to the directory structure.
Are you building on Windows or Linux? If on Linux then there is the
possibility that there is a backslash where there should be a forward
slash as a path separator, or that there is a case sensitivity problem
in the file names where the files are #included.
I have just tried importing the project and building it myself and
didn’t have a problem. I can’t see any backslashes in the include paths.
Hello
Hein Tibosch, Thanx for reply,
i did settings as per you suggested to me(project property->C/C++ General->path and symbol->add directory path->C:\FreeRTOSV8.2.1\FreeRTOS\Source\include\FreeRTOS.h) and then compile but unfortunately i got lots of errors!
at which point I’m going wrong?
Thank you for reply,
can you give me bit more info. at where i do include these path and how?
apart from this when i build freeRTOS demo file then I’m getting following message
Trace started. Hit a key to dump trace file to disk (does not work from Eclipse console)"
Thanks admin for reply,
as per your suggestion for FreeRTOS demo i show include directories in
C/C++
Build->Settings->GCC C Compiler->Includes
and i found that all links that you post earlier in previous comment.
Now i need to develop my own code that’s why I’ve created new c project named “mahendra” and wrote hello world simple code for FreeRTOS and include that all include path, and hit build but still I’m getting same error!
please consider attached snap
Regards
Mahendra
When using variables like ${ProjName}, it is possible to move your project later on to another location.
PS. If you are more experienced using Make and Makefile (like I am), then I would advice to import a Makefile project into Eclipse (see import Makefile Project). In that case Eclipse will call Make to execute your Makefile and then run the created .ELF
After doing such thing when i hit build then i found sane errors and warnings that I’d impact earlier.
Error list,
07:53:07 **** Incremental Build of configuration Default for project MS_RTOS ****
make all
‘Building file: …/scr/ms.c’
‘Invoking: GCC C Compiler’
gcc -O2 -g -Wall -c -fmessage-length=0 -MMD -MP -MF"scr/ms.d" -MT"scr/ms.d" -o “scr/ms.o” “…/scr/ms.c”
…/scr/ms.c:10:21: warning: FreeRTOS.h: No such file or directory
…/scr/ms.c:11:18: task.h: No such file or directory
…/scr/ms.c: In function hello_world_task': ../scr/ms.c:17: warning: implicit declaration of function vTaskDelay’
…/scr/ms.c: In function main': ../scr/ms.c:23: warning: implicit declaration of function xTaskCreate’
…/scr/ms.c:23: warning: implicit declaration of function STACK_BYTES' ../scr/ms.c:24: warning: implicit declaration of function vTaskStartScheduler’
make: *** [scr/ms.o] Error 1
07:53:08 Build Finished (took 1s.136ms)
Now can any one tell me whether I’ve taken right steps to create make file and include path or not?
Thanx for reply,
But it’s not solved yet, as I’d created new project file, and it’s not properly links to “FreeRTOS.h” and “task.h” for my first “hello world” simulation.
In previous post I’d show that all steps from new file creation to links to them it’s header file and sofar I’m not getting my answer at which points i did mistake.
Guys, it’s my hardcore prescription to learn freeRTOS, please help me
hello there,
as i told i’d solved problem associated with freeRTOS demo project output and I’m getting proper output.
But problem is when i create new project and build it then its shows lots of errors and warnings like,
08:10:53 **** Incremental Build of configuration Debug for project ms_RTOS ****
Info: Internal Builder is used for build
gcc “-IC:\Users\LENOVO\workspace\ms_RTOS” “-IC:\FreeRTOSV8.2.1\FreeRTOS\Source” “-IC:\FreeRTOSV8.2.1\FreeRTOS\Source\include” -O0 -g3 -Wall -c -fmessage-length=0 -o “scr\ms.o” “…\scr\ms.c”
In file included from …\scr\ms.c:11:
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/FreeRTOS.h:98:28: FreeRTOSConfig.h: No such file or directory
In file included from C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/FreeRTOS.h:104,
from …\scr\ms.c:11:
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/portable.h:94:24: portmacro.h: No such file or directory
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/portable.h:114:3: #error “Invalid portBYTE_ALIGNMENT definition”
from …\scr\ms.c:11:
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/portable.h:136: error: syntax error before ‘’ token
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/portable.h:136: error: syntax error before '’ token
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/portable.h:136: warning: type defaults to int' in declaration of pxPortInitialiseStack’
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/portable.h:136: warning: data definition has no type or storage class
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/portable.h:173: error: syntax error before “xPortStartScheduler”
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/portable.h:173: warning: type defaults to int' in declaration of xPortStartScheduler’
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/portable.h:173: warning: data definition has no type or storage class
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/FreeRTOS.h:113:3: #error Missing definition: configMINIMAL_STACK_SIZE must be defined in FreeRTOSConfig.h. configMINIMAL_STACK_SIZE defines the size (in words) of the stack allocated to the idle task. Refer to the demo project provided for your port for a suitable value.
C:/FreeRTOSV8.2.1/FreeRTOS/Source/include/FreeRTOS.h:117:3: #error Missing definition: configMAX_PRIORITIES must be defined in FreeRTOSConfig.h. See the Configuration section of the FreeRTOS API documentation for details.
Did you look at the error messages in the output produced by the compiler? Did you follow the instructions on the FreeRTOS website to create a new project?
The clue might be right at the top where it says “FreeRTOSConfig.h: No such file or directory”.
Thanx for reply, http://www.freertos.org/Creating-a-new-FreeRTOS-project.html
as per described FreeRTOS sight for making new project i’d include all necessary file but still i’m getting errors which are mostly associated with task.c file
please have a look results of project and errors,and guide me at which point i’m getting wrong!
…\tasks.c:1834: error: syntax error before ‘’ token
…\tasks.c:1835: warning: return type defaults to int' ..\tasks.c: In function uxTaskGetSystemState’:
…\tasks.c:1836: error: syntax error before “uxTask”
…\tasks.c:1841: error: uxArraySize' undeclared (first use in this function) ..\tasks.c:1847: error: uxQueue’ undeclared (first use in this function)
…\tasks.c:1848: error: uxTask' undeclared (first use in this function) ..\tasks.c:1848: error: pxTaskStatusArray’ undeclared (first use in this function)
…\tasks.c:1850: error: syntax error before numeric constant
…\tasks.c:1854: error: syntax error before ‘)’ token
…\tasks.c:1855: error: syntax error before ‘)’ token
…\tasks.c:1875: error: pulTotalRunTime' undeclared (first use in this function) ..\tasks.c: At top level: ..\tasks.c:1939: error: xTaskIncrementTick’ declared as function returning a function
…\tasks.c: In function xTaskIncrementTick': ..\tasks.c:1940: error: pxTCB’ undeclared (first use in this function)
…\tasks.c:1941: error: syntax error before “xItemValue”
…\tasks.c:1942: error: function xSwitchRequired' is initialized like a variable ..\tasks.c:1942: error: cast specifies function type ..\tasks.c:1947: error: cast specifies function type ..\tasks.c:1947: error: cast specifies function type ..\tasks.c:1948: error: cast specifies function type ..\tasks.c:1957: error: syntax error before "xConstTickCount" ..\tasks.c:1959: error: xConstTickCount’ undeclared (first use in this function)
…\tasks.c:1959: error: syntax error before numeric constant
…\tasks.c:1961: error: request for member uxNumberOfItems' in something not a structure or union ..\tasks.c:1961: error: syntax error before numeric constant ..\tasks.c:1961: error: pxTemp’ undeclared (first use in this function)
…\tasks.c:1961: error: wrong type argument to increment
…\tasks.c:1976: error: request for member uxNumberOfItems' in something not a structure or union ..\tasks.c:1976: error: syntax error before numeric constant ..\tasks.c:1976: error: cast specifies function type ..\tasks.c:1983: error: syntax error before numeric constant ..\tasks.c:1992: error: syntax error before ')' token ..\tasks.c:1992: error: request for member xListEnd’ in something not a structure or union
…\tasks.c:1993: error: xItemValue' undeclared (first use in this function) ..\tasks.c:2036: error: request for member uxPriority’ in something not a structure or union
…\tasks.c:2038: error: cast specifies function type
…\tasks.c: At top level:
…\tasks.c:2055: error: syntax error before ‘{’ token
…\tasks.c:2114: error: syntax error before “TaskHookFunction_t”
…\tasks.c: In function vTaskSetApplicationTaskTag': ..\tasks.c:2116: error: xTCB’ undeclared (first use in this function)
…\tasks.c:2120: error: xTask' undeclared (first use in this function) ..\tasks.c:2122: error: syntax error before ')' token ..\tasks.c:2126: error: syntax error before ')' token ..\tasks.c:2132: error: pxHookFunction’ undeclared (first use in this function)
…\tasks.c:2141: error: syntax error before “xTaskGetApplicationTaskTag”
…\tasks.c:2142: warning: return type defaults to int' ..\tasks.c: In function xTaskGetApplicationTaskTag’:
…\tasks.c:2143: error: xTCB' undeclared (first use in this function) ..\tasks.c:2144: error: TaskHookFunction_t’ undeclared (first use in this function)
…\tasks.c:2144: error: syntax error before “xReturn”
…\tasks.c:2149: error: syntax error before ‘)’ token
…\tasks.c:2153: error: syntax error before ‘)’ token
…\tasks.c:2173: error: xTaskCallApplicationTaskHook' declared as function returning a function ..\tasks.c: In function xTaskCallApplicationTaskHook’:
…\tasks.c:2174: error: xTCB' undeclared (first use in this function) ..\tasks.c:2180: error: syntax error before ')' token ..\tasks.c:2184: error: syntax error before ')' token ..\tasks.c:2193: error: cast specifies function type ..\tasks.c:2196: warning: return makes integer from pointer without a cast ..\tasks.c: In function vTaskSwitchContext’:
…\tasks.c:2204: error: cast specifies function type
…\tasks.c:2208: error: cast specifies function type
…\tasks.c:2212: error: cast specifies function type
…\tasks.c:2232: error: request for member ulRunTimeCounter' in something not a structure or union ..\tasks.c:2248: error: syntax error before "uxTopPriority" ..\tasks.c:2248: warning: implicit declaration of function portGET_HIGHEST_PRIORITY’
…\tasks.c:2248: error: uxTopPriority' undeclared (first use in this function) ..\tasks.c:2248: error: syntax error before "const" ..\tasks.c:2248: error: pxConstList’ undeclared (first use in this function)
…\tasks.c:2262: error: syntax error before '’ token
…\tasks.c: In function vTaskPlaceOnEventList': ..\tasks.c:2264: error: syntax error before "xTimeToWake" ..\tasks.c:2266: error: pxEventList’ undeclared (first use in this function)
…\tasks.c:2275: error: request for member xEventListItem' in something not a structure or union ..\tasks.c:2280: error: request for member xGenericListItem’ in something not a structure or union
…\tasks.c:2280: error: syntax error before numeric constant
…\tasks.c:2306: warning: type defaults to int' in declaration of prvAddCurrentTaskToDelayedList’
…\tasks.c:2306: warning: parameter names (without types) in function declaration
…\tasks.c:2306: warning: data definition has no type or storage class
…\tasks.c:2307: error: syntax error before ‘}’ token
…\tasks.c:2321: error: syntax error before ‘’ token
…\tasks.c: In function vTaskPlaceOnUnorderedEventList': ..\tasks.c:2323: error: syntax error before "xTimeToWake" ..\tasks.c:2325: error: pxEventList’ undeclared (first use in this function)
…\tasks.c:2334: error: request for member xEventListItem' in something not a structure or union ..\tasks.c:2334: error: xItemValue’ undeclared (first use in this function)
…\tasks.c:2341: error: request for member xEventListItem' in something not a structure or union ..\tasks.c:2346: error: request for member xGenericListItem’ in something not a structure or union
…\tasks.c:2346: error: syntax error before numeric constant
…\tasks.c:2372: warning: type defaults to int' in declaration of prvAddCurrentTaskToDelayedList’
…\tasks.c:2372: warning: parameter names (without types) in function declaration
…\tasks.c:2372: warning: data definition has no type or storage class
…\tasks.c:2373: error: syntax error before ‘}’ token
…\tasks.c:2389: error: syntax error before '’ token
…\tasks.c: In function vTaskPlaceOnEventListRestricted': ..\tasks.c:2391: error: syntax error before "xTimeToWake" ..\tasks.c:2393: error: pxEventList’ undeclared (first use in this function)
…\tasks.c:2405: error: request for member xEventListItem' in something not a structure or union ..\tasks.c:2411: error: request for member xGenericListItem’ in something not a structure or union
…\tasks.c:2411: error: syntax error before numeric constant
…\tasks.c:2424: warning: type defaults to int' in declaration of xTimeToWake’
…\tasks.c:2424: error: xTicksToWait' undeclared here (not in a function) ..\tasks.c:2424: warning: data definition has no type or storage class ..\tasks.c:2426: error: syntax error before '(' token ..\tasks.c:2426: error: syntax error before '(' token ..\tasks.c:2426: error: syntax error before '(' token ..\tasks.c:2426: error: syntax error before '(' token ..\tasks.c:2427: warning: type defaults to int’ in declaration of prvAddCurrentTaskToDelayedList' ..\tasks.c:2427: warning: parameter names (without types) in function declaration ..\tasks.c:2427: warning: data definition has no type or storage class ..\tasks.c:2428: error: syntax error before '}' token ..\tasks.c:2433: warning: type defaults to int’ in declaration of List_t' ..\tasks.c:2433: error: syntax error before '*' token ..\tasks.c:2434: error: xTaskRemoveFromEventList’ declared as function returning a function
…\tasks.c: In function xTaskRemoveFromEventList': ..\tasks.c:2435: error: pxUnblockedTCB’ undeclared (first use in this function)
…\tasks.c:2451: error: syntax error before ‘)’ token
…\tasks.c:2451: error: pxEventList' undeclared (first use in this function) ..\tasks.c:2455: error: cast specifies function type ..\tasks.c:2467: error: request for member uxPriority’ in something not a structure or union
…\tasks.c:2472: error: cast specifies function type
…\tasks.c:2476: error: cast specifies function type
…\tasks.c:2480: error: cast specifies function type
…\tasks.c:2497: warning: return makes integer from pointer without a cast
…\tasks.c:2501: warning: type defaults to int' in declaration of TickType_t’
…\tasks.c:2501: error: syntax error before “xItemValue”
…\tasks.c:2502: error: xTaskRemoveFromUnorderedEventList' declared as function returning a function ..\tasks.c: In function xTaskRemoveFromUnorderedEventList’:
…\tasks.c:2503: error: pxUnblockedTCB' undeclared (first use in this function) ..\tasks.c:2508: error: cast specifies function type ..\tasks.c:2511: error: pxEventListItem’ undeclared (first use in this function)
…\tasks.c:2511: error: xItemValue' undeclared (first use in this function) ..\tasks.c:2515: error: syntax error before ')' token ..\tasks.c:2525: error: request for member uxPriority’ in something not a structure or union
…\tasks.c:2531: error: cast specifies function type
…\tasks.c:2535: error: cast specifies function type
…\tasks.c:2539: error: cast specifies function type
…\tasks.c:2542: warning: return makes integer from pointer without a cast
…\tasks.c:2546: error: syntax error before ‘’ token
…\tasks.c: In function vTaskSetTimeOutState': ..\tasks.c:2548: error: pxTimeOut’ undeclared (first use in this function)
…\tasks.c:2554: error: syntax error before '’ token
…\tasks.c:2555: error: xTaskCheckForTimeOut' declared as function returning a function ..\tasks.c: In function xTaskCheckForTimeOut’:
…\tasks.c:2558: error: pxTimeOut' undeclared (first use in this function) ..\tasks.c:2559: error: pxTicksToWait’ undeclared (first use in this function)
…\tasks.c:2564: error: syntax error before “xConstTickCount”
…\tasks.c:2570: error: syntax error before numeric constant
…\tasks.c:2589: warning: type defaults to int' in declaration of vTaskSetTimeOutState’
…\tasks.c:2589: warning: parameter names (without types) in function declaration
…\tasks.c:2589: error: conflicting types for ‘vTaskSetTimeOutState’
…\tasks.c:2547: error: previous definition of ‘vTaskSetTimeOutState’ was here
…\tasks.c:2589: warning: data definition has no type or storage class
…\tasks.c:2590: warning: type defaults to int' in declaration of xReturn’
…\tasks.c:2590: error: redefinition of ‘xReturn’
…\tasks.c:706: error: previous definition of ‘xReturn’ was here
…\tasks.c:2590: error: ‘xReturn’ redeclared as different kind of symbol
…\tasks.c:2556: error: previous declaration of ‘xReturn’ was here
…\tasks.c:2590: error: cast specifies function type
…\tasks.c:2590: warning: data definition has no type or storage class
…\tasks.c:2591: error: syntax error before ‘}’ token
…\tasks.c:2597: warning: type defaults to int' in declaration of vPortExitCritical’
…\tasks.c:2597: warning: data definition has no type or storage class
…\tasks.c:2599: error: syntax error before “return”
…\tasks.c: In function vTaskMissedYield': ..\tasks.c:2605: error: cast specifies function type ..\tasks.c: At top level: ..\tasks.c:2611: error: syntax error before "uxTaskGetTaskNumber" ..\tasks.c:2612: warning: return type defaults to int’
…\tasks.c: In function uxTaskGetTaskNumber': ..\tasks.c:2613: error: syntax error before "uxReturn" ..\tasks.c:2614: error: pxTCB’ undeclared (first use in this function)
…\tasks.c:2618: error: syntax error before ‘)’ token
…\tasks.c:2619: error: uxReturn' undeclared (first use in this function) ..\tasks.c: At top level: ..\tasks.c:2634: warning: type defaults to int’ in declaration of UBaseType_t' ..\tasks.c:2634: error: syntax error before "uxHandle" ..\tasks.c: In function vTaskSetTaskNumber’:
…\tasks.c:2636: error: pxTCB' undeclared (first use in this function) ..\tasks.c:2638: error: xTask’ undeclared (first use in this function)
…\tasks.c:2640: error: syntax error before ‘)’ token
…\tasks.c:2641: error: uxHandle' undeclared (first use in this function) ..\tasks.c: In function prvIdleTask’:
…\tasks.c:2689: error: syntax error before numeric constant
…\tasks.c:2701: error: syntax error before ‘{’ token
…\tasks.c:2709: warning: type defaults to int' in declaration of vApplicationIdleHook’
…\tasks.c:2709: warning: data definition has no type or storage class
…\tasks.c:2710: error: syntax error before ‘}’ token
…\tasks.c:2805: error: syntax error before ‘’ token
…\tasks.c: In function prvInitialiseTCBVariables': ..\tasks.c:2807: error: syntax error before "x" ..\tasks.c:2810: error: x’ undeclared (first use in this function)
…\tasks.c:2810: error: syntax error before numeric constant
…\tasks.c:2810: error: syntax error before ‘)’ token
…\tasks.c:2817: error: pcName' undeclared (first use in this function) ..\tasks.c:2819: error: break statement not within loop or switch ..\tasks.c: At top level: ..\tasks.c:2829: error: syntax error before '->' token ..\tasks.c:2850: error: syntax error before '&' token ..\tasks.c:2851: error: syntax error before '&' token ..\tasks.c:2855: error: syntax error before '&' token ..\tasks.c:2858: error: syntax error before '&' token ..\tasks.c:2859: error: syntax error before '&' token ..\tasks.c: In function prvInitialiseTaskLists’:
…\tasks.c:2971: error: syntax error before “uxPriority”
…\tasks.c:2973: error: syntax error before numeric constant
…\tasks.c:2973: error: syntax error before ‘)’ token
…\tasks.c:2978: error: syntax error before ‘&’ token
…\tasks.c:2978: warning: type defaults to int' in declaration of vListInitialise’
…\tasks.c:2978: error: conflicting types for ‘vListInitialise’
…\list.h:386: error: previous declaration of ‘vListInitialise’ was here
…\tasks.c:2978: warning: data definition has no type or storage class
…\tasks.c:2979: error: syntax error before ‘&’ token
…\tasks.c:2979: warning: type defaults to int' in declaration of vListInitialise’
…\tasks.c:2979: warning: data definition has no type or storage class
…\tasks.c:2980: error: syntax error before ‘&’ token
…\tasks.c:2980: warning: type defaults to int' in declaration of vListInitialise’
…\tasks.c:2980: warning: data definition has no type or storage class
…\tasks.c:2996: warning: type defaults to int' in declaration of pxDelayedTaskList’
…\tasks.c:2996: error: conflicting types for ‘pxDelayedTaskList’
…\tasks.c:218: error: previous declaration of ‘pxDelayedTaskList’ was here
…\tasks.c:2996: warning: initialization makes integer from pointer without a cast
…\tasks.c:2996: warning: data definition has no type or storage class
…\tasks.c:2997: warning: type defaults to int' in declaration of pxOverflowDelayedTaskList’
…\tasks.c:2997: error: conflicting types for ‘pxOverflowDelayedTaskList’
…\tasks.c:219: error: previous declaration of ‘pxOverflowDelayedTaskList’ was here
…\tasks.c:2997: warning: initialization makes integer from pointer without a cast
…\tasks.c:2997: warning: data definition has no type or storage class
…\tasks.c:2998: error: syntax error before ‘}’ token
…\tasks.c: In function prvCheckTasksWaitingTermination': ..\tasks.c:3009: error: syntax error before numeric constant ..\tasks.c:3013: error: request for member uxNumberOfItems’ in something not a structure or union
…\tasks.c:3013: error: syntax error before numeric constant
…\tasks.c:3017: error: cast specifies function type
…\tasks.c:3019: error: pxTCB' undeclared (first use in this function) ..\tasks.c:3023: error: syntax error before ')' token ..\tasks.c:3023: error: request for member xListEnd’ in something not a structure or union
…\tasks.c:3039: error: syntax error before ‘}’ token
…\tasks.c:3042: warning: type defaults to int' in declaration of TickType_t’
…\tasks.c:3042: error: syntax error before “xTimeToWake”
…\tasks.c:3043: error: conflicting types for ‘prvAddCurrentTaskToDelayedList’
…\tasks.c:2427: error: previous declaration of ‘prvAddCurrentTaskToDelayedList’ was here
…\tasks.c: In function prvAddCurrentTaskToDelayedList': ..\tasks.c:3045: error: request for member xGenericListItem’ in something not a structure or union
…\tasks.c:3050: error: request for member xGenericListItem' in something not a structure or union ..\tasks.c:3055: error: request for member xGenericListItem’ in something not a structure or union
…\tasks.c:3072: error: syntax error before '’ token
…\tasks.c:3072: error: syntax error before “StackType_t”
…\tasks.c:3073: warning: return type defaults to int' ..\tasks.c: In function prvAllocateTCBAndStack’:
…\tasks.c:3074: error: pxNewTCB' undeclared (first use in this function) ..\tasks.c:3102: error: StackType_t’ undeclared (first use in this function)
…\tasks.c:3105: error: syntax error before ‘)’ token
…\tasks.c:3105: error: usStackDepth' undeclared (first use in this function) ..\tasks.c:3111: error: syntax error before ')' token ..\tasks.c: At top level: ..\tasks.c:3149: error: syntax error before "prvListTaskWithinSingleList" ..\tasks.c:3149: error: syntax error before '*' token ..\tasks.c:3150: warning: return type defaults to int’
…\tasks.c: In function prvListTaskWithinSingleList': ..\tasks.c:3151: error: syntax error before '*' token ..\tasks.c:3154: error: pxList’ undeclared (first use in this function)
…\tasks.c:3154: error: syntax error before numeric constant
…\tasks.c:3156: error: pxConstList' undeclared (first use in this function) ..\tasks.c:3156: error: pxFirstTCB’ undeclared (first use in this function)
…\tasks.c:3162: error: syntax error before “do”
…\tasks.c:3164: error: syntax error before ‘->’ token
…\tasks.c:3164: warning: type defaults to int' in declaration of pxNextTCB’
…\tasks.c:3164: error: pxConstList' undeclared here (not in a function) ..\tasks.c:3164: warning: data definition has no type or storage class ..\tasks.c:3164: error: syntax error before '}' token ..\tasks.c:3166: error: uxTask’ undeclared here (not in a function)
…\tasks.c:3166: error: syntax error before ‘.’ token
…\tasks.c:3167: error: syntax error before ‘.’ token
…\tasks.c:3168: error: syntax error before ‘.’ token
…\tasks.c:3169: error: syntax error before ‘.’ token
…\tasks.c:3170: error: syntax error before ‘.’ token
…\tasks.c: In function prvTaskCheckFreeStackSpace': ..\tasks.c:3244: error: StackType_t’ undeclared (first use in this function)
…\tasks.c:3254: error: syntax error before “uxTaskGetStackHighWaterMark”
…\tasks.c:3255: warning: return type defaults to int' ..\tasks.c: In function uxTaskGetStackHighWaterMark’:
…\tasks.c:3256: error: pxTCB' undeclared (first use in this function) ..\tasks.c:3258: error: syntax error before "uxReturn" ..\tasks.c:3260: error: syntax error before ')' token ..\tasks.c:3260: error: syntax error before ')' token ..\tasks.c:3272: error: uxReturn’ undeclared (first use in this function)
…\tasks.c:3272: error: syntax error before “prvTaskCheckFreeStackSpace”
…\tasks.c:3282: error: syntax error before ‘*’ token
…\tasks.c: In function prvDeleteTCB': ..\tasks.c:3287: error: pxTCB’ undeclared (first use in this function)
…\tasks.c: In function prvResetNextTaskUnblockTime': ..\tasks.c:3320: error: pxTCB’ undeclared (first use in this function)
…\tasks.c:3322: error: invalid type argument of ->' ..\tasks.c:3322: error: syntax error before numeric constant ..\tasks.c:3322: error: cast specifies function type ..\tasks.c:3328: error: syntax error before numeric constant ..\tasks.c:3336: error: syntax error before ')' token ..\tasks.c:3336: error: invalid type argument of ->’
…\tasks.c:3362: error: xTaskGetSchedulerState' declared as function returning a function ..\tasks.c: In function xTaskGetSchedulerState’:
…\tasks.c:3365: error: cast specifies function type
…\tasks.c:3367: error: cast specifies function type
…\tasks.c:3371: error: cast specifies function type
…\tasks.c:3373: error: cast specifies function type
…\tasks.c:3377: error: cast specifies function type
…\tasks.c:3381: warning: return makes integer from pointer without a cast
…\tasks.c: In function vTaskPriorityInherit': ..\tasks.c:3391: error: syntax error before "const" ..\tasks.c:3400: error: pxTCB’ undeclared (first use in this function)
…\tasks.c:3400: error: request for member uxPriority' in something not a structure or union ..\tasks.c:3407: error: syntax error before "pxCurrentTCB" ..\tasks.c:3416: error: cast specifies function type ..\tasks.c:3418: error: syntax error before numeric constant ..\tasks.c:3428: error: request for member uxPriority’ in something not a structure or union
…\tasks.c:3431: error: syntax error before “else”
…\tasks.c:3437: error: syntax error before ‘(’ token
…\tasks.c:3438: error: syntax error before ‘}’ token
…\tasks.c:3456: error: xTaskPriorityDisinherit' declared as function returning a function ..\tasks.c: In function xTaskPriorityDisinherit’:
…\tasks.c:3457: error: syntax error before “const”
…\tasks.c:3458: error: function xReturn' is initialized like a variable ..\tasks.c:3458: error: cast specifies function type ..\tasks.c:3466: error: pxTCB’ undeclared (first use in this function)
…\tasks.c:3476: error: syntax error before numeric constant
…\tasks.c:3487: error: syntax error before “else”
…\tasks.c:3494: error: syntax error before ‘(’ token
…\tasks.c:3495: error: syntax error before ‘->’ token
…\tasks.c:3500: error: syntax error before ‘&’ token
…\tasks.c:3501: error: syntax error before ‘(’ token
…\tasks.c:3501: error: syntax error before ‘&’ token
…\tasks.c:3511: warning: type defaults to int' in declaration of xReturn’
…\tasks.c:3511: error: redefinition of ‘xReturn’
…\tasks.c:2590: error: previous definition of ‘xReturn’ was here
…\tasks.c:3511: error: ‘xReturn’ redeclared as different kind of symbol
…\tasks.c:3458: error: previous declaration of ‘xReturn’ was here
…\tasks.c:3511: error: cast specifies function type
…\tasks.c:3511: warning: data definition has no type or storage class
…\tasks.c:3512: error: syntax error before ‘}’ token
…\tasks.c: In function prvWriteNameToBuffer': ..\tasks.c:3609: error: invalid lvalue in assignment ..\tasks.c:3609: warning: comparison between pointer and integer ..\tasks.c:3609: error: wrong type argument to increment ..\tasks.c:3611: error: array subscript is not an integer ..\tasks.c:3615: error: array subscript is not an integer ..\tasks.c:3618: error: array subscript is not an integer ..\tasks.c: In function vTaskList’:
…\tasks.c:3628: error: pxTaskStatusArray' undeclared (first use in this function) ..\tasks.c:3629: error: syntax error before "uxArraySize" ..\tasks.c:3662: error: uxArraySize’ undeclared (first use in this function)
…\tasks.c:3673: error: x' undeclared (first use in this function) ..\tasks.c: In function vTaskGetRunTimeStats’:
…\tasks.c:3720: error: pxTaskStatusArray' undeclared (first use in this function) ..\tasks.c:3721: error: syntax error before "uxArraySize" ..\tasks.c:3760: error: uxArraySize’ undeclared (first use in this function)
…\tasks.c:3777: error: x' undeclared (first use in this function) ..\tasks.c: At top level: ..\tasks.c:3840: error: syntax error before "uxTaskResetEventItemValue" ..\tasks.c:3841: warning: return type defaults to int’
…\tasks.c: In function uxTaskResetEventItemValue': ..\tasks.c:3842: error: syntax error before "uxReturn" ..\tasks.c:3844: error: uxReturn’ undeclared (first use in this function)
…\tasks.c:3844: error: request for member xEventListItem' in something not a structure or union ..\tasks.c:3848: error: request for member xEventListItem’ in something not a structure or union
…\tasks.c:3848: error: syntax error before “pxCurrentTCB”
…\tasks.c: In function pvTaskIncrementMutexHeldCount': ..\tasks.c:3862: error: request for member uxMutexesHeld’ in something not a structure or union
…\tasks.c:3873: error: syntax error before “TickType_t”
…\tasks.c: In function ulTaskNotifyTake': ..\tasks.c:3875: error: syntax error before "xTimeToWake" ..\tasks.c:3881: error: request for member ulNotifiedValue’ in something not a structure or union
…\tasks.c:3884: error: request for member eNotifyState' in something not a structure or union ..\tasks.c:3886: error: syntax error before numeric constant ..\tasks.c:3904: error: syntax error before numeric constant ..\tasks.c:3876: warning: unused variable ulReturn’
…\tasks.c:3937: warning: type defaults to int' in declaration of vPortYieldFromISR’
…\tasks.c:3937: warning: data definition has no type or storage class
…\tasks.c:3938: error: syntax error before ‘}’ token
…\tasks.c:3949: warning: type defaults to int' in declaration of vPortExitCritical’
…\tasks.c:3949: warning: data definition has no type or storage class
…\tasks.c:3951: warning: type defaults to int' in declaration of vPortEnterCritical’
…\tasks.c:3951: warning: data definition has no type or storage class
…\tasks.c:3952: error: syntax error before ‘{’ token
…\tasks.c:3973: warning: type defaults to int' in declaration of vPortExitCritical’
…\tasks.c:3973: warning: data definition has no type or storage class
…\tasks.c:3975: error: syntax error before “return”
…\tasks.c:3983: error: syntax error before “TickType_t”
…\tasks.c:3984: error: xTaskNotifyWait' declared as function returning a function ..\tasks.c: In function xTaskNotifyWait’:
…\tasks.c:3985: error: syntax error before “xTimeToWake”
…\tasks.c:3991: error: request for member eNotifyState' in something not a structure or union ..\tasks.c:3996: error: request for member ulNotifiedValue’ in something not a structure or union
…\tasks.c:3996: error: ulBitsToClearOnEntry' undeclared (first use in this function) ..\tasks.c:3999: error: request for member eNotifyState’ in something not a structure or union
…\tasks.c:4001: error: syntax error before numeric constant
…\tasks.c:4019: error: syntax error before numeric constant
…\tasks.c:4052: warning: type defaults to int' in declaration of vPortYieldFromISR’
…\tasks.c:4052: warning: data definition has no type or storage class
…\tasks.c:4053: error: syntax error before ‘}’ token
…\tasks.c:4064: warning: type defaults to int' in declaration of vPortExitCritical’
…\tasks.c:4064: warning: data definition has no type or storage class
…\tasks.c:4066: warning: type defaults to int' in declaration of vPortEnterCritical’
…\tasks.c:4066: warning: data definition has no type or storage class
…\tasks.c:4067: error: syntax error before ‘{’ token
…\tasks.c:4089: warning: type defaults to int' in declaration of xReturn’
…\tasks.c:4089: error: redefinition of ‘xReturn’
…\tasks.c:3511: error: previous definition of ‘xReturn’ was here
…\tasks.c:4089: error: ‘xReturn’ redeclared as different kind of symbol
…\tasks.c:3986: error: previous declaration of ‘xReturn’ was here
…\tasks.c:4089: error: cast specifies function type
…\tasks.c:4089: warning: data definition has no type or storage class
…\tasks.c:4090: error: syntax error before ‘}’ token
…\tasks.c:4094: warning: type defaults to int' in declaration of vPortExitCritical’
…\tasks.c:4094: warning: data definition has no type or storage class
…\tasks.c:4096: error: syntax error before “return”
…\tasks.c:4105: error: xTaskGenericNotify' declared as function returning a function ..\tasks.c: In function xTaskGenericNotify’:
…\tasks.c:4106: error: pxTCB' undeclared (first use in this function) ..\tasks.c:4108: error: function xReturn’ is initialized like a variable
…\tasks.c:4108: error: cast specifies function type
…\tasks.c:4111: error: syntax error before ‘)’ token
…\tasks.c:4146: error: cast specifies function type
…\tasks.c:4167: error: request for member uxPriority' in something not a structure or union ..\tasks.c:4185: warning: return makes integer from pointer without a cast ..\tasks.c: At top level: ..\tasks.c:4194: error: xTaskNotifyFromISR’ declared as function returning a function
…\tasks.c: In function xTaskNotifyFromISR': ..\tasks.c:4195: error: pxTCB’ undeclared (first use in this function)
…\tasks.c:4197: error: function xReturn' is initialized like a variable ..\tasks.c:4197: error: cast specifies function type ..\tasks.c:4198: error: syntax error before "uxSavedInterruptStatus" ..\tasks.c:4220: error: syntax error before ')' token ..\tasks.c:4222: error: uxSavedInterruptStatus’ undeclared (first use in this function)
…\tasks.c:4222: error: configMAX_SYSCALL_INTERRUPT_PRIORITY' undeclared (first use in this function) ..\tasks.c:4250: error: cast specifies function type ..\tasks.c:4268: error: cast specifies function type ..\tasks.c:4280: error: request for member uxPriority’ in something not a structure or union
…\tasks.c:4286: error: cast specifies function type
…\tasks.c:4297: warning: return makes integer from pointer without a cast
…\tasks.c:4222: error: unknown register name r0' in asm’
…\tasks.c:4295: error: unknown register name r0' in asm’
…\tasks.c: In function vTaskNotifyGiveFromISR': ..\tasks.c:4307: error: pxTCB’ undeclared (first use in this function)
…\tasks.c:4309: error: syntax error before “uxSavedInterruptStatus”
…\tasks.c:4331: error: syntax error before ‘)’ token
…\tasks.c:4333: error: uxSavedInterruptStatus' undeclared (first use in this function) ..\tasks.c:4333: error: configMAX_SYSCALL_INTERRUPT_PRIORITY’ undeclared (first use in this function)
…\tasks.c:4349: error: cast specifies function type
…\tasks.c:4361: error: request for member uxPriority' in something not a structure or union ..\tasks.c:4367: error: cast specifies function type ..\tasks.c:4333: error: unknown register name r0’ in asm' ..\tasks.c:4376: error: unknown register name r0’ in asm' ..\tasks.c: At top level: ..\list.h:210: error: storage size of xListEnd’ isn’t known
…\tasks.c:143: error: storage size of xGenericListItem' isn't known ..\tasks.c:144: error: storage size of xEventListItem’ isn’t known
…\tasks.c:245: warning: ‘xSchedulerRunning’ declared static' but never defined ..\tasks.c:247: warning: 'xYieldPending' declared static’ but never defined
…\tasks.c:248: warning: ‘xNumOfOverflows’ declared static' but never defined ..\tasks.c:2970: warning: 'prvInitialiseTaskLists' defined but not used ..\tasks.c:486: warning: 'prvAddCurrentTaskToDelayedList' declared static’ but never defined
…\tasks.c:3235: warning: ‘prvTaskCheckFreeStackSpace’ defined but not used
Difficult to say what is wrong here - but it still looks like an include file problem. As you don’t have a “could not find header file” type error could it be you are including the wrong portmacro.h file?
