I would like to understand FreeRTOS so I started building my own project from scratch with an ESP32 (Firebeetle). Basic setup, doing some LED blinking and writing to Serial works fine. I am stuck on implementing MQTT. I copied a lot of stuff from vendors/espressif/boards/esp32/aws_demos/application_code/main.c and demos/coreMQTT/mqtt_demo_mutual_auth.c.
The repository is on github under vinceTTs/freertos
Building and flashing to device is ok. Unfortunately I am not able to connect to AWS:
The output is the same when router turned on and off. So I guess the Board is not yet making any wifi-connection? Is there any way to get the status within freertos (like a callback/task of the wifi status)?
Any help and recommendations appreciated.
Thank you ![]()
