I’m new to using the Free RTOS OS, and I tried to adapt a demo to my board.
I followed the guidelines found on the website, and tried to flash a LED.
When I use an ordinary main(), it works, So I know the HArdware is OK.
But when I replace the main, by the original main, from the demo. I’t doesn’t work.
I commented aal the extra tasks, so only the FlashLEDTask was there.
How doe I chek if the systemtick is OK.
Any other things I should check?
I don’t think so…
Thanks !!
I go check it out.
The demo, on the webstie is not complete… it even doesn’t do any rcc configuration.
For now, I have to go partying, but I’ll look at it, very soon.
Thanks!!!!
Do you have an example of the setup of interrupts?
Thanks man! I Didn’t setup the vetor table right. Now it works like a charm!!\
This happened because my hardware uses a LED on port G, while the demo only supports until port E (the ST-Firmware lib was from 2007) So I decided to use a brand new FWLib… and unfortunately, it had a slightly different structure. And here, I used the new, and original vector.c. So that was the problem.
Thanks for the kint, you saved me a whole day, and som hedaches.
