jembeddev wrote on Tuesday, March 12, 2019:
I built a SDK with FreeRTOS using MCUXpresso SDK builder.
I was wondering how I would open/load that SDK into IAR EW?
Any help is greatly appreciated!
Thanks
Thanks
rtel wrote on Wednesday, March 13, 2019:
You would not be able to open the MCUXpresso project in IAR, but you can create a project and add the same source files into it - provided there is nothing that is GCC specific that is not supported by IAR.
I find the easiest way to do this is to find an example IAR project for your target hardware, make sure that works, then use it as a base for the project you want to create. That way you start with the correct start up files, linker script, etc.
jembeddev wrote on Sunday, March 17, 2019:
Thank you, I was able to do this successfully.
