catalin80 wrote on Monday, February 24, 2014:
I need to build the LPC2106 example using Sourcery CodeBench Lite 2013.05-24 and I receive an error:
arm-none-linux-gnueabi-gcc -Wall -Wextra -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-align -Wsign-compare -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wunused -D RUN_FROM_RAM -DGCC_ARM7 -I. -I…/…/Source/include -I. -I…/…/…/FreeRTOS/Source/portable/RVDS/ARM7_LPC21xx -I…/Common/include -mcpu=arm7tdmi -T -fomit-frame-pointer -fno-strict-aliasing -fno-dwarf2-cfi-asm …/…/Source/portable/GCC/ARM7_LPC2000/portISR.o serial/serialISR.o main.o serial/serial.o ParTest/ParTest.o …/Common/Minimal/integer.o …/Common/Minimal/flash.o …/Common/Minimal/PollQ.o …/Common/Minimal/comtest.o …/Common/Minimal/flop.o …/Common/Minimal/semtest.o …/Common/Minimal/dynamic.o …/Common/Minimal/BlockQ.o …/…/Source/tasks.o …/…/Source/queue.o …/…/Source/list.o …/…/Source/portable/MemMang/heap_2.o …/…/Source/portable/GCC/ARM7_LPC2000/port.o -nostartfiles boot.s -Xlinker -ortosdemo.elf -Xlinker -M -Xlinker -Map=rtosdemo.map
/home/catalin/CodeSourcery/Sourcery_CodeBench_Lite_for_ARM_GNU_Linux/bin/…/lib/gcc/arm-none-linux-gnueabi/4.7.3/…/…/…/…/arm-none-linux-gnueabi/bin/ld: cannot open linker script file -fomit-frame-pointer: No such file or directory
collect2: error: ld returned 1 exit status
make: *** [rtosdemo.elf] Error 1
The FreeRTOS release is 8.0.0.
Is there someone that solved this problem (or know an suitable solution)?
Thank you !
