hkubota wrote on Monday, February 23, 2009:
When I tried to make an LPC2103 work with the LPC2106 gcc FreeRTOS demo work, I thought “That’s gonna be easy”. Well, it is not.
I am at my wits end. I know the board works. The compiler is good, the linker too, I modified the obvious suspects (crystal frequency change to 19.66MHz from 14.xMHz, change of multiplier/divider for the PLL accordingly, change of the linker file to reflect the smaller flash and RAM of the LPC2103 vs. LPC2106, I use ARM only).
Yet I don’t get a single blinking LED out of it.
Same when using an LPC2148 (similar configuration changes).
Unfortunately I do not have the Olimex 2106 board.
Is that ARM7_LPC2106_GCC demo working for anyone?
Harald
