Hello, I am trying to compile (using Keil) an app into an STM32F407IG and get these errors:
Error: L6218E: Undefined symbol FLASH_segment_end (referred from port.o).
Error: L6218E: Undefined symbol FLASH_segment_start (referred from port.o).
Error: L6218E: Undefined symbol SRAM_segment_end (referred from port.o).
Error: L6218E: Undefined symbol SRAM_segment_start (referred from port.o).
Error: L6218E: Undefined symbol privileged_data_end (referred from port.o).
Error: L6218E: Undefined symbol privileged_data_start (referred from port.o).
Error: L6218E: Undefined symbol privileged_functions_end (referred from port.o).
Error: L6218E: Undefined symbol syscalls_flash_end (referred from port.o).
Error: L6218E: Undefined symbol syscalls_flash_start (referred from port.o).
I have founded in port.c this conditional extern variables:
static void prvSetupMPU( void )
#if defined( __ARMCC_VERSION )
/* Declaration when these variable are defined in code instead of being
* exported from linker scripts. /
extern uint32_t * privileged_functions_end;
extern uint32_t * FLASH_segment_start;
extern uint32_t * FLASH_segment_end;
extern uint32_t * privileged_data_start;
extern uint32_t * privileged_data_end;
#else
/ Declaration when these variable are exported from linker scripts. */
extern uint32_t privileged_functions_end[];
extern uint32_t FLASH_segment_start[];
extern uint32_t FLASH_segment_end[];
extern uint32_t privileged_data_start[];
extern uint32_t privileged_data_end[];
and these:
static void prvSVCHandler( uint32_t pulParam )
uint8_t ucSVCNumber;
uint32_t ulPC;
#if( configENFORCE_SYSTEM_CALLS_FROM_KERNEL_ONLY == 1 )
/ Declaration when these variable are defined in code instead of being
extern uint32_t * syscalls_flash_start;
extern uint32_t * syscalls_flash_end;
#else
/ Declaration when these variable are exported from linker scripts. /
extern uint32_t syscalls_flash_start[];
extern uint32_t syscalls_flash_end[];
#endif / #if defined( __ARMCC_VERSION ) /
#endif / #if( configENFORCE_SYSTEM_CALLS_FROM_KERNEL_ONLY == 1 ) */
Does anybody know what might be missing to cause these error messages?
I am using this port for my app: FreeRTOS\Source\portable\GCC\ARM_CM4_MPU
Thank you for your help
