Hi, I’m experiencing some difficulties with the compilation of one of the demos in the FreeRTOS MPU version. Specifically, I’m trying to compile the “CORTEX_MPU_M3_NUCLEO_L152RE_GCC” project and, even if I followed the tutorial on how to import the project into an eclipse-based IDE, when I compile the project I get the following error:
STM32L152RETX_FLASH.ld:203 cannot move location counter backwards (from 0000000020004220 to 0000000020000200)
The line that throws the error is part of this block:
/* FreeRTOS kernel data. */
.privileged_data :
. = ALIGN(4);
_sdata = .; /* Create a global symbol at data start. */
*(privileged_data)
. = ALIGN(4);
FILL(0xDEAD);
/* Ensure that un-privileged data is placed after the region reserved
* for privileged kernel data. */
/* Note that dot (.) actually refers to the byte offset from the start
* of the current section (.privileged_data in this case). As a result,
* setting dot (.) to a value sets the size of the section. */
. = __privileged_data_region_size__; **//THIS LINE THROWS THE ERROR**
} >RAM AT> FLASH
I’ve made sure to be using the ARM GCC compiler, other than that I ran out of ideas. If somebody can help me figure out what’s going on I would appreciate it!
Thanks in advance
