matben243 wrote on Tuesday, January 13, 2015:
Hi, thanks for your help. The dump of app.a is shown below. I can see some FreeRTOS functions inside there, although I assume there should be more? Just to be clear using make with the src make file works with no errors, it is once I call make with the project make file that I get the linker errors.
In archive app.a:
startup.o: file format elf32-littlearm
Disassembly of section .text:
00000000 <Default_Handler>:
0: e7fe b.n 0 <Default_Handler>
2: bf00 nop
00000004 <Reset_Handler>:
4: 4668 mov r0, sp
6: f020 0107 bic.w r1, r0, #7
a: 468d mov sp, r1
c: b501 push {r0, lr}
e: f240 0100 movw r1, #0
12: f240 0000 movw r0, #0
16: f2c0 0100 movt r1, #0
1a: f2c0 0000 movt r0, #0
1e: 4281 cmp r1, r0
20: d00c beq.n 3c <Reset_Handler+0x38>
22: f240 0300 movw r3, #0
26: f2c0 0300 movt r3, #0
2a: 4298 cmp r0, r3
2c: d206 bcs.n 3c <Reset_Handler+0x38>
2e: 43c2 mvns r2, r0
30: 4413 add r3, r2
32: f023 0203 bic.w r2, r3, #3
36: 3204 adds r2, #4
38: f7ff fffe bl 0
3c: f240 0000 movw r0, #0
40: f240 0300 movw r3, #0
44: f2c0 0000 movt r0, #0
48: f2c0 0300 movt r3, #0
4c: 4298 cmp r0, r3
4e: d207 bcs.n 60 <Reset_Handler+0x5c>
50: 43c2 mvns r2, r0
52: 4413 add r3, r2
54: f023 0203 bic.w r2, r3, #3
58: 3204 adds r2, #4
5a: 2100 movs r1, #0
5c: f7ff fffe bl 0
60: f240 0300 movw r3, #0
64: f2c0 0300 movt r3, #0
68: f023 4368 bic.w r3, r3, #3892314112 ; 0xe8000000
6c: f023 027f bic.w r2, r3, #127 ; 0x7f
70: f44f 436d mov.w r3, #60672 ; 0xed00
74: f042 6200 orr.w r2, r2, #134217728 ; 0x8000000
78: f2ce 0300 movt r3, #57344 ; 0xe000
7c: 609a str r2, [r3, #8]
7e: f7ff fffe bl 0
82: f7ff fffe bl 0
86: e7fe b.n 0 <_sidata>
00000088 <__Init_Data>:
88: f240 0100 movw r1, #0
8c: f240 0000 movw r0, #0
90: f2c0 0100 movt r1, #0
94: f2c0 0000 movt r0, #0
98: 4281 cmp r1, r0
9a: b508 push {r3, lr}
9c: d00c beq.n b8 <__Init_Data+0x30>
9e: f240 0300 movw r3, #0
a2: f2c0 0300 movt r3, #0
a6: 4298 cmp r0, r3
a8: d206 bcs.n b8 <__Init_Data+0x30>
aa: 43c2 mvns r2, r0
ac: 4413 add r3, r2
ae: f023 0203 bic.w r2, r3, #3
b2: 3204 adds r2, #4
b4: f7ff fffe bl 0
b8: f240 0000 movw r0, #0
bc: f240 0300 movw r3, #0
c0: f2c0 0000 movt r0, #0
c4: f2c0 0300 movt r3, #0
c8: 4298 cmp r0, r3
ca: d209 bcs.n e0 <__Init_Data+0x58>
cc: 43c2 mvns r2, r0
ce: 4413 add r3, r2
d0: f023 0203 bic.w r2, r3, #3
d4: 3204 adds r2, #4
d6: 2100 movs r1, #0
d8: e8bd 4008 ldmia.w sp!, {r3, lr}
dc: f7ff bffe b.w 0
e0: bd08 pop {r3, pc}
e2: bf00 nop
main.o: file format elf32-littlearm
00000000 :
0: f44f 5580 mov.w r5, #4096 ; 0x1000
4: b580 push {r7, lr}
6: f2c4 0501 movt r5, #16385 ; 0x4001
a: f44f 5780 mov.w r7, #4096 ; 0x1000
e: f04f 5680 mov.w r6, #268435456 ; 0x10000000
12: 2400 movs r4, #0
14: f2c4 2448 movt r4, #16968 ; 0x4248
18: 612f str r7, [r5, #16]
1a: f240 3147 movw r1, #839 ; 0x347
1e: 4620 mov r0, r4
20: f6c3 7180 movt r1, #16256 ; 0x3f80
24: f7ff fffe bl 0 <__aeabi_fdiv>
28: f24b 7117 movw r1, #46871 ; 0xb717
2c: f6c3 01d1 movt r1, #14545 ; 0x38d1
30: 4604 mov r4, r0
32: f7ff fffe bl 0 <__aeabi_fcmpgt>
36: 2800 cmp r0, #0
38: d1ef bne.n 1a <vTask1+0x1a>
3a: 2400 movs r4, #0
3c: f2c4 2448 movt r4, #16968 ; 0x4248
40: 612e str r6, [r5, #16]
42: f240 3147 movw r1, #839 ; 0x347
46: 4620 mov r0, r4
48: f6c3 7180 movt r1, #16256 ; 0x3f80
4c: f7ff fffe bl 0 <__aeabi_fdiv>
50: f24b 7117 movw r1, #46871 ; 0xb717
54: f6c3 01d1 movt r1, #14545 ; 0x38d1
58: 4604 mov r4, r0
5a: f7ff fffe bl 0 <__aeabi_fcmpgt>
5e: 2800 cmp r0, #0
60: d1ef bne.n 42 <vTask1+0x42>
62: e7d6 b.n 12 <vTask1+0x12>
00000064 :
64: b510 push {r4, lr}
66: 2400 movs r4, #0
68: f2c4 2448 movt r4, #16968 ; 0x4248
6c: f240 3147 movw r1, #839 ; 0x347
70: 4620 mov r0, r4
72: f6c3 7180 movt r1, #16256 ; 0x3f80
76: f7ff fffe bl 0 <__aeabi_fdiv>
7a: f24b 7117 movw r1, #46871 ; 0xb717
7e: f6c3 01d1 movt r1, #14545 ; 0x38d1
82: 4604 mov r4, r0
84: f7ff fffe bl 0 <__aeabi_fcmpgt>
88: 2800 cmp r0, #0
8a: d1ef bne.n 6c <DelayByDiv+0x8>
8c: bd10 pop {r4, pc}
8e: bf00 nop
00000090 <FLASH_ReadOutProtection_Enable>:
90: b508 push {r3, lr}
92: f7ff fffe bl 0 <FLASH_GetReadOutProtectionStatus>
96: 2801 cmp r0, #1
98: d006 beq.n a8 <FLASH_ReadOutProtection_Enable+0x18>
9a: f7ff fffe bl 0 <FLASH_Unlock>
9e: 2001 movs r0, #1
a0: f7ff fffe bl 0 <FLASH_ReadOutProtection>
a4: 2804 cmp r0, #4
a6: d000 beq.n aa <FLASH_ReadOutProtection_Enable+0x1a>
a8: bd08 pop {r3, pc}
aa: f3bf 8f4f dsb sy
ae: f44f 426d mov.w r2, #60672 ; 0xed00
b2: f2ce 0200 movt r2, #57344 ; 0xe000
b6: 68d1 ldr r1, [r2, #12]
b8: 2304 movs r3, #4
ba: f401 61e0 and.w r1, r1, #1792 ; 0x700
be: f2c0 53fa movt r3, #1530 ; 0x5fa
c2: 430b orrs r3, r1
c4: 60d3 str r3, [r2, #12]
c6: f3bf 8f4f dsb sy
ca: e7fe b.n ca <FLASH_ReadOutProtection_Enable+0x3a>
Disassembly of section .text.startup:
00000000 :
0: b510 push {r4, lr}
2: 2010 movs r0, #16
4: b086 sub sp, #24
6: 2101 movs r1, #1
8: f7ff fffe bl 0 <RCC_APB2PeriphClockCmd>
c: f44f 5080 mov.w r0, #4096 ; 0x1000
10: 2202 movs r2, #2
12: 2310 movs r3, #16
14: f2c4 0001 movt r0, #16385 ; 0x4001
18: a905 add r1, sp, #20
1a: f44f 5480 mov.w r4, #4096 ; 0x1000
1e: f88d 2016 strb.w r2, [sp, #22]
22: f88d 3017 strb.w r3, [sp, #23]
26: f8ad 4014 strh.w r4, [sp, #20]
2a: f7ff fffe bl 0 <GPIO_Init>
2e: f7ff fffe bl 90 <FLASH_ReadOutProtection_Enable>
32: 2300 movs r3, #0
34: f240 0000 movw r0, #0
38: f240 0100 movw r1, #0
3c: 9300 str r3, [sp, #0]
3e: 9301 str r3, [sp, #4]
40: 9302 str r3, [sp, #8]
42: 9303 str r3, [sp, #12]
44: f2c0 0100 movt r1, #0
48: 2282 movs r2, #130 ; 0x82
4a: f2c0 0000 movt r0, #0
4e: f7ff fffe bl 0
52: f7ff fffe bl 0
56: e7fe b.n 56 <main+0x56>
FreeRTOS.o: file format elf32-littlearm
00000000 :
0: b5f0 push {r4, r5, r6, r7, lr}
2: f240 0400 movw r4, #0
6: b085 sub sp, #20
8: f2c0 0400 movt r4, #0
c: f7ff fffe bl 0
10: 6827 ldr r7, [r4, #0]
12: b1c7 cbz r7, 46 <xTimerCreateTimerTask+0x46>
14: f7ff fffe bl 0
18: 6823 ldr r3, [r4, #0]
1a: b38b cbz r3, 80 <xTimerCreateTimerTask+0x80>
1c: 2300 movs r3, #0
1e: 2202 movs r2, #2
20: f240 0000 movw r0, #0
24: f240 0100 movw r1, #0
28: e88d 000c stmia.w sp, {r2, r3}
2c: 9302 str r3, [sp, #8]
2e: 9303 str r3, [sp, #12]
30: f2c0 0000 movt r0, #0
34: f2c0 0100 movt r1, #0
38: f44f 7282 mov.w r2, #260 ; 0x104
3c: f7ff fffe bl 0
40: b1f0 cbz r0, 80 <xTimerCreateTimerTask+0x80>
42: b005 add sp, #20
44: bdf0 pop {r4, r5, r6, r7, pc}
46: 1d26 adds r6, r4, #4
48: 4630 mov r0, r6
4a: f104 0518 add.w r5, r4, #24
4e: f7ff fffe bl 0
52: 4628 mov r0, r5
54: f7ff fffe bl 0
58: 463a mov r2, r7
5a: 200a movs r0, #10
5c: 210c movs r1, #12
5e: 62e6 str r6, [r4, #44] ; 0x2c
60: 6325 str r5, [r4, #48] ; 0x30
62: f7ff fffe bl 0
66: 6020 str r0, [r4, #0]
68: b168 cbz r0, 86 <xTimerCreateTimerTask+0x86>
6a: f240 0100 movw r1, #0
6e: f2c0 0100 movt r1, #0
72: f7ff fffe bl 0
76: f7ff fffe bl 0
7a: 6823 ldr r3, [r4, #0]
7c: 2b00 cmp r3, #0
7e: d1cd bne.n 1c <xTimerCreateTimerTask+0x1c>
80: f7ff fffe bl 0
84: e7fe b.n 0
86: f7ff fffe bl 0
8a: e7fe b.n 8a <xTimerCreateTimerTask+0x8a>
0000008c :
8c: e92d 4ff0 stmdb sp!, {r4, r5, r6, r7, r8, r9, sl, fp, lr}
90: 460e mov r6, r1
92: b083 sub sp, #12
94: 4683 mov fp, r0
96: 4692 mov sl, r2
98: 461f mov r7, r3
9a: b1e9 cbz r1, d8 <xTimerCreate+0x4c>
9c: 202c movs r0, #44 ; 0x2c
9e: f7ff fffe bl 0
a2: 4604 mov r4, r0
a4: b1a0 cbz r0, d0 <xTimerCreate+0x44>
a6: f240 0500 movw r5, #0
aa: f2c0 0500 movt r5, #0
ae: f7ff fffe bl 0
b2: 682a ldr r2, [r5, #0]
b4: b19a cbz r2, de <xTimerCreate+0x52>
b6: f7ff fffe bl 0
ba: 9b0c ldr r3, [sp, #48] ; 0x30
bc: f8c4 b000 str.w fp, [r4]
c0: 61a6 str r6, [r4, #24]
c2: f8c4 a01c str.w sl, [r4, #28]
c6: 6227 str r7, [r4, #32]
c8: 6263 str r3, [r4, #36] ; 0x24
ca: 1d20 adds r0, r4, #4
cc: f7ff fffe bl 0
d0: 4620 mov r0, r4
d2: b003 add sp, #12
d4: e8bd 8ff0 ldmia.w sp!, {r4, r5, r6, r7, r8, r9, sl, fp, pc}
d8: f7ff fffe bl 0
dc: e7fe b.n dc <xTimerCreate+0x50>
de: f105 0904 add.w r9, r5, #4
e2: 4648 mov r0, r9
e4: f105 0818 add.w r8, r5, #24
e8: 9201 str r2, [sp, #4]
ea: f7ff fffe bl 0
ee: 4640 mov r0, r8
f0: f7ff fffe bl 0
f4: 9a01 ldr r2, [sp, #4]
f6: 200a movs r0, #10
f8: 210c movs r1, #12
fa: f8c5 902c str.w r9, [r5, #44] ; 0x2c
fe: f8c5 8030 str.w r8, [r5, #48] ; 0x30
102: f7ff fffe bl 0
106: 6028 str r0, [r5, #0]
108: b130 cbz r0, 118 <xTimerCreate+0x8c>
10a: f240 0100 movw r1, #0
10e: f2c0 0100 movt r1, #0
112: f7ff fffe bl 0
116: e7ce b.n ffffffa0 <ulPortSetInterruptMask+0xffffffa0>
118: f7ff fffe bl 0
11c: e7fe b.n 11c <xTimerCreate+0x90>
11e: bf00 nop
00000120 :
120: b570 push {r4, r5, r6, lr}
122: f240 0400 movw r4, #0
126: f2c0 0400 movt r4, #0
12a: 6825 ldr r5, [r4, #0]
12c: b084 sub sp, #16
12e: b1ed cbz r5, 16c <xTimerGenericCommand+0x4c>
130: 2905 cmp r1, #5
132: 9101 str r1, [sp, #4]
134: 9202 str r2, [sp, #8]
136: 9003 str r0, [sp, #12]
138: dd07 ble.n 14a <xTimerGenericCommand+0x2a>
13a: 461a mov r2, r3
13c: 4628 mov r0, r5
13e: a901 add r1, sp, #4
140: 2300 movs r3, #0
142: f7ff fffe bl 0
146: b004 add sp, #16
148: bd70 pop {r4, r5, r6, pc}
14a: f7ff fffe bl 0
14e: 2802 cmp r0, #2
150: bf11 iteee ne
152: 2200 movne r2, #0
154: 6820 ldreq r0, [r4, #0]
156: a901 addeq r1, sp, #4
158: 9a08 ldreq r2, [sp, #32]
15a: bf0f iteee eq
15c: 2300 moveq r3, #0
15e: 6820 ldrne r0, [r4, #0]
160: 4613 movne r3, r2
162: a901 addne r1, sp, #4
164: f7ff fffe bl 0
168: b004 add sp, #16
16a: bd70 pop {r4, r5, r6, pc}
16c: 4628 mov r0, r5
16e: b004 add sp, #16
170: bd70 pop {r4, r5, r6, pc}
172: bf00 nop
00000174 :
174: e92d 4ff0 stmdb sp!, {r4, r5, r6, r7, r8, r9, sl, fp, lr}
178: f240 0400 movw r4, #0
17c: f2c0 0400 movt r4, #0
180: b089 sub sp, #36 ; 0x24
182: 4627 mov r7, r4
184: 6ae3 ldr r3, [r4, #44] ; 0x2c
186: 2600 movs r6, #0
188: 681d ldr r5, [r3, #0]
18a: f1d5 0501 rsbs r5, r5, #1
18e: bf38 it cc
190: 2500 movcc r5, #0
192: b90d cbnz r5, 198 <prvTimerTask+0x24>
194: 68db ldr r3, [r3, #12]
196: 681e ldr r6, [r3, #0]
198: f7ff fffe bl 0
19c: f7ff fffe bl 0
1a0: 6b63 ldr r3, [r4, #52] ; 0x34
1a2: 4682 mov sl, r0
1a4: 4298 cmp r0, r3
1a6: d352 bcc.n 24e <prvTimerTask+0xda>
1a8: f085 0301 eor.w r3, r5, #1
1ac: 4286 cmp r6, r0
1ae: bf8c ite hi
1b0: 2300 movhi r3, #0
1b2: f003 0301 andls.w r3, r3, #1
1b6: 6378 str r0, [r7, #52] ; 0x34
1b8: 2b00 cmp r3, #0
1ba: d175 bne.n 2a8 <prvTimerTask+0x134>
1bc: ebca 0106 rsb r1, sl, r6
1c0: 6838 ldr r0, [r7, #0]
1c2: f7ff fffe bl 0
1c6: f7ff fffe bl 0
1ca: 2800 cmp r0, #0
1cc: f000 8094 beq.w 2f8 <prvTimerTask+0x184>
1d0: 2200 movs r2, #0
1d2: 4613 mov r3, r2
1d4: 6820 ldr r0, [r4, #0]
1d6: a902 add r1, sp, #8
1d8: f7ff fffe bl 0
1dc: 2800 cmp r0, #0
1de: d0d1 beq.n 184 <prvTimerTask+0x10>
1e0: 9b02 ldr r3, [sp, #8]
1e2: 2b00 cmp r3, #0
1e4: dbf4 blt.n 1d0 <prvTimerTask+0x5c>
1e6: f8dd a010 ldr.w sl, [sp, #16]
1ea: f8da 3014 ldr.w r3, [sl, #20]
1ee: b11b cbz r3, 1f8 <prvTimerTask+0x84>
1f0: f10a 0004 add.w r0, sl, #4
1f4: f7ff fffe bl 0
1f8: f7ff fffe bl 0
1fc: 6b63 ldr r3, [r4, #52] ; 0x34
1fe: 4683 mov fp, r0
200: 4298 cmp r0, r3
202: d342 bcc.n 28a <prvTimerTask+0x116>
204: 9b02 ldr r3, [sp, #8]
206: f8c4 b034 str.w fp, [r4, #52] ; 0x34
20a: 2b09 cmp r3, #9
20c: d8e0 bhi.n 1d0 <prvTimerTask+0x5c>
20e: 2001 movs r0, #1
210: fa00 f303 lsl.w r3, r0, r3
214: f413 7f04 tst.w r3, #528 ; 0x210
218: f040 80e9 bne.w 3ee <prvTimerTask+0x27a>
21c: f013 0fc7 tst.w r3, #199 ; 0xc7
220: f040 80be bne.w 3a0 <prvTimerTask+0x22c>
224: 069b lsls r3, r3, #26
226: d5d3 bpl.n 1d0 <prvTimerTask+0x5c>
228: 4650 mov r0, sl
22a: f7ff fffe bl 0
22e: e7cf b.n 1d0 <prvTimerTask+0x5c>
230: 68db ldr r3, [r3, #12]
232: 68dd ldr r5, [r3, #12]
234: f8d3 b000 ldr.w fp, [r3]
238: f105 0804 add.w r8, r5, #4
23c: 4640 mov r0, r8
23e: f7ff fffe bl 0
242: 6a6b ldr r3, [r5, #36] ; 0x24
244: 4628 mov r0, r5
246: 4798 blx r3
248: 69eb ldr r3, [r5, #28]
24a: 2b01 cmp r3, #1
24c: d03d beq.n 2ca <prvTimerTask+0x156>
24e: 6ae3 ldr r3, [r4, #44] ; 0x2c
250: f240 0600 movw r6, #0
254: 681a ldr r2, [r3, #0]
256: f2c0 0600 movt r6, #0
25a: 2a00 cmp r2, #0
25c: d1e8 bne.n 230 <prvTimerTask+0xbc>
25e: 6b32 ldr r2, [r6, #48] ; 0x30
260: f8c6 a034 str.w sl, [r6, #52] ; 0x34
264: 62f2 str r2, [r6, #44] ; 0x2c
266: 6333 str r3, [r6, #48] ; 0x30
268: f7ff fffe bl 0
26c: e7b0 b.n 1d0 <prvTimerTask+0x5c>
26e: 68d2 ldr r2, [r2, #12]
270: 68d5 ldr r5, [r2, #12]
272: 6816 ldr r6, [r2, #0]
274: f105 0804 add.w r8, r5, #4
278: 4640 mov r0, r8
27a: f7ff fffe bl 0
27e: 6a6a ldr r2, [r5, #36] ; 0x24
280: 4628 mov r0, r5
282: 4790 blx r2
284: 69ea ldr r2, [r5, #28]
286: 2a01 cmp r2, #1
288: d02a beq.n 2e0 <prvTimerTask+0x16c>
28a: 6ae2 ldr r2, [r4, #44] ; 0x2c
28c: f240 0900 movw r9, #0
290: 6811 ldr r1, [r2, #0]
292: f2c0 0900 movt r9, #0
296: 2900 cmp r1, #0
298: d1e9 bne.n 26e <prvTimerTask+0xfa>
29a: f8d9 1030 ldr.w r1, [r9, #48] ; 0x30
29e: f8c9 2030 str.w r2, [r9, #48] ; 0x30
2a2: f8c9 102c str.w r1, [r9, #44] ; 0x2c
2a6: e7ad b.n ffffff5e <xTaskResumeAll+0xffffff5e>
2a8: f7ff fffe bl 0
2ac: 6afb ldr r3, [r7, #44] ; 0x2c
2ae: 68db ldr r3, [r3, #12]
2b0: 68dd ldr r5, [r3, #12]
2b2: f105 0b04 add.w fp, r5, #4
2b6: 4658 mov r0, fp
2b8: f7ff fffe bl 0
2bc: 69eb ldr r3, [r5, #28]
2be: 2b01 cmp r3, #1
2c0: d01d beq.n 2fe <prvTimerTask+0x18a>
2c2: 6a6b ldr r3, [r5, #36] ; 0x24
2c4: 4628 mov r0, r5
2c6: 4798 blx r3
2c8: e782 b.n 1d0 <prvTimerTask+0x5c>
2ca: 69ab ldr r3, [r5, #24]
2cc: 4641 mov r1, r8
2ce: 445b add r3, fp
2d0: 455b cmp r3, fp
2d2: d931 bls.n 338 <prvTimerTask+0x1c4>
2d4: 606b str r3, [r5, #4]
2d6: 612d str r5, [r5, #16]
2d8: 6af0 ldr r0, [r6, #44] ; 0x2c
2da: f7ff fffe bl 0
2de: e7b6 b.n 24e <prvTimerTask+0xda>
2e0: 69aa ldr r2, [r5, #24]
2e2: 4641 mov r1, r8
2e4: 4432 add r2, r6
2e6: 42b2 cmp r2, r6
2e8: d93b bls.n 362 <prvTimerTask+0x1ee>
2ea: 606a str r2, [r5, #4]
2ec: 612d str r5, [r5, #16]
2ee: f8d9 002c ldr.w r0, [r9, #44] ; 0x2c
2f2: f7ff fffe bl 0
2f6: e7c8 b.n ffffff94 <vPortYield+0xffffff94>
2f8: f7ff fffe bl 0
2fc: e768 b.n 1d0 <prvTimerTask+0x5c>
2fe: 69ab ldr r3, [r5, #24]
300: 612d str r5, [r5, #16]
302: 18f2 adds r2, r6, r3
304: 4592 cmp sl, r2
306: 606a str r2, [r5, #4]
308: d340 bcc.n 38c <prvTimerTask+0x218>
30a: ebc6 0a0a rsb sl, r6, sl
30e: 4553 cmp r3, sl
310: d841 bhi.n 396 <prvTimerTask+0x222>
312: 683b ldr r3, [r7, #0]
314: b16b cbz r3, 332 <prvTimerTask+0x1be>
316: 2200 movs r2, #0
318: 9205 str r2, [sp, #20]
31a: 9606 str r6, [sp, #24]
31c: 9507 str r5, [sp, #28]
31e: f7ff fffe bl 0
322: 2200 movs r2, #0
324: 4613 mov r3, r2
326: 6838 ldr r0, [r7, #0]
328: a905 add r1, sp, #20
32a: f7ff fffe bl 0
32e: 2800 cmp r0, #0
330: d1c7 bne.n 2c2 <prvTimerTask+0x14e>
332: f7ff fffe bl 0
336: e7fe b.n 336 <prvTimerTask+0x1c2>
338: 6833 ldr r3, [r6, #0]
33a: b17b cbz r3, 35c <prvTimerTask+0x1e8>
33c: 2000 movs r0, #0
33e: 9005 str r0, [sp, #20]
340: f8cd b018 str.w fp, [sp, #24]
344: 9507 str r5, [sp, #28]
346: f7ff fffe bl 0
34a: 2200 movs r2, #0
34c: 6830 ldr r0, [r6, #0]
34e: 4613 mov r3, r2
350: a905 add r1, sp, #20
352: f7ff fffe bl 0
356: 2800 cmp r0, #0
358: f47f af79 bne.w 24e <prvTimerTask+0xda>
35c: f7ff fffe bl 0
360: e7fe b.n 360 <prvTimerTask+0x1ec>
362: f8d9 2000 ldr.w r2, [r9]
366: b172 cbz r2, 386 <prvTimerTask+0x212>
368: 2300 movs r3, #0
36a: 9305 str r3, [sp, #20]
36c: 9606 str r6, [sp, #24]
36e: 9507 str r5, [sp, #28]
370: f7ff fffe bl 0
374: 2200 movs r2, #0
376: f8d9 0000 ldr.w r0, [r9]
37a: 4613 mov r3, r2
37c: a905 add r1, sp, #20
37e: f7ff fffe bl 0
382: 2800 cmp r0, #0
384: d181 bne.n 28a <prvTimerTask+0x116>
386: f7ff fffe bl 0
38a: e7fe b.n 38a <prvTimerTask+0x216>
38c: 4659 mov r1, fp
38e: 6af8 ldr r0, [r7, #44] ; 0x2c
390: f7ff fffe bl 0
394: e795 b.n 2c2 <prvTimerTask+0x14e>
396: 4659 mov r1, fp
398: 6b38 ldr r0, [r7, #48] ; 0x30
39a: f7ff fffe bl 0
39e: e790 b.n 2c2 <prvTimerTask+0x14e>
3a0: 9b03 ldr r3, [sp, #12]
3a2: f8da 1018 ldr.w r1, [sl, #24]
3a6: f8ca a010 str.w sl, [sl, #16]
3aa: 18ca adds r2, r1, r3
3ac: 455a cmp r2, fp
3ae: f8ca 2004 str.w r2, [sl, #4]
3b2: d82e bhi.n 412 <prvTimerTask+0x29e>
3b4: ebc3 030b rsb r3, r3, fp
3b8: 4299 cmp r1, r3
3ba: d839 bhi.n 430 <prvTimerTask+0x2bc>
3bc: f8da 3024 ldr.w r3, [sl, #36] ; 0x24
3c0: 4650 mov r0, sl
3c2: 4798 blx r3
3c4: f8da 301c ldr.w r3, [sl, #28]
3c8: 2b01 cmp r3, #1
3ca: f47f af01 bne.w 1d0 <prvTimerTask+0x5c>
3ce: f8da 2018 ldr.w r2, [sl, #24]
3d2: 9b03 ldr r3, [sp, #12]
3d4: 2100 movs r1, #0
3d6: 441a add r2, r3
3d8: 9100 str r1, [sp, #0]
3da: 4650 mov r0, sl
3dc: 460b mov r3, r1
3de: f7ff fffe bl 120
3e2: 2800 cmp r0, #0
3e4: f47f aef4 bne.w 1d0 <prvTimerTask+0x5c>
3e8: f7ff fffe bl 0
3ec: e7fe b.n 3ec <prvTimerTask+0x278>
3ee: 9b03 ldr r3, [sp, #12]
3f0: f8ca 3018 str.w r3, [sl, #24]
3f4: b313 cbz r3, 43c <prvTimerTask+0x2c8>
3f6: 445b add r3, fp
3f8: 455b cmp r3, fp
3fa: f8ca 3004 str.w r3, [sl, #4]
3fe: f8ca a010 str.w sl, [sl, #16]
402: f10a 0104 add.w r1, sl, #4
406: bf94 ite ls
408: 6b38 ldrls r0, [r7, #48] ; 0x30
40a: 6af8 ldrhi r0, [r7, #44] ; 0x2c
40c: f7ff fffe bl 0
410: e6de b.n 1d0 <prvTimerTask+0x5c>
412: 455b cmp r3, fp
414: bf94 ite ls
416: 2100 movls r1, #0
418: 2101 movhi r1, #1
41a: 4293 cmp r3, r2
41c: bf88 it hi
41e: 2100 movhi r1, #0
420: 2900 cmp r1, #0
422: d1cb bne.n 3bc <prvTimerTask+0x248>
424: f10a 0104 add.w r1, sl, #4
428: 6af8 ldr r0, [r7, #44] ; 0x2c
42a: f7ff fffe bl 0
42e: e6cf b.n 1d0 <prvTimerTask+0x5c>
430: f10a 0104 add.w r1, sl, #4
434: 6b38 ldr r0, [r7, #48] ; 0x30
436: f7ff fffe bl 0
43a: e6c9 b.n fffffd96 <ulPortSetInterruptMask+0xfffffd96>
43c: f7ff fffe bl 0
440: e7fe b.n 440 <prvTimerTask+0x2cc>
442: bf00 nop
00000444 :
444: 6800 ldr r0, [r0, #0]
446: 4770 bx lr
00000448 :
448: b510 push {r4, lr}
44a: 4604 mov r4, r0
44c: f7ff fffe bl 0
450: 6964 ldr r4, [r4, #20]
452: 3400 adds r4, #0
454: bf18 it ne
456: 2401 movne r4, #1
458: f7ff fffe bl 0
45c: 4620 mov r0, r4
45e: bd10 pop {r4, pc}
00000460 :
460: 6a00 ldr r0, [r0, #32]
462: 4770 bx lr
