echortos wrote on Thursday, December 03, 2009:
Dear all
Now My application is use pic24JF128GA010. But I want to move my application to pic24FJ128GB110. Thank you
Best regards.
Dear all
Best regards.
davedoors wrote on Thursday, December 03, 2009:
What are the differences. The cores are the same so the simple answer is yes it can be ported. However if the 110 varient has much less flash or RAM then you might get problems from that. I would guess all you have to do is change the map file and change the header files that are included.
