danhepler wrote on Tuesday, September 13, 2016:
There are a total of three bugs.
Two bugs are found in StaticTask_t which are evident comparing the definition of StaticTask_t in FreeRTOS.h and TCB_t in task.c. This causes a false stack overflow failure because the stack overflow check fails on the first byte (ucDelayAborted is written as pdFALSE or pdTRUE). These may also cause weird behaviour with xTaskAbortDelayalthough I have not verified this.
typedef struct xSTATIC_TCB
void *pxDummy1;
#if ( portUSING_MPU_WRAPPERS == 1 )
xMPU_SETTINGS xDummy2;
StaticListItem_t xDummy3[ 2 ];
UBaseType_t uxDummy5;
void *pxDummy6;
uint8_t ucDummy7[ configMAX_TASK_NAME_LEN ];
#if ( portSTACK_GROWTH > 0 )
void *pxDummy8;
#if ( portCRITICAL_NESTING_IN_TCB == 1 )
UBaseType_t uxDummy9;
#if ( configUSE_TRACE_FACILITY == 1 )
UBaseType_t uxDummy10[ 2 ];
#if ( configUSE_MUTEXES == 1 )
UBaseType_t uxDummy12[ 2 ];
#if ( configUSE_APPLICATION_TASK_TAG == 1 )
void *pxDummy14;
#if( configNUM_THREAD_LOCAL_STORAGE_POINTERS > 0 )
void *pvDummy15[ configNUM_THREAD_LOCAL_STORAGE_POINTERS ];
#if ( configGENERATE_RUN_TIME_STATS == 1 )
uint32_t ulDummy16;
#if ( configUSE_NEWLIB_REENTRANT == 1 )
struct _reent xDummy17;
#if ( configUSE_TASK_NOTIFICATIONS == 1 )
uint32_t ulDummy18;
uint8_t ucDummy19;
#if( ( configSUPPORT_STATIC_ALLOCATION == 1 ) && ( configSUPPORT_DYNAMIC_ALLOCATION == 1 ) )
uint8_t uxDummy20;
} StaticTask_t;
- StaticTask_t should have the last uxDummy20 conditional compile flag changed to the following to include the ports with portUSING_MPU_WRAPPERS enabled:
#if( ( ( configSUPPORT_STATIC_ALLOCATION == 1 ) && ( configSUPPORT_DYNAMIC_ALLOCATION == 1 ) ) || ( portUSING_MPU_WRAPPERS == 1 ) )
uint8_t uxDummy20;
- StaticTask_t should add a missing ucDummy21 to account for ucDelayAborted if INCLUDE_xTaskAbortDelay is enabled:
#if( INCLUDE_xTaskAbortDelay == 1 )
uint8_t ucDummy21;
- Additionally, there is a very misleading comment in xTaskCreateStatic() in tasks.c:
TaskHandle_t xTaskCreateStatic( TaskFunction_t pxTaskCode,
const char * const pcName,
const uint32_t ulStackDepth,
void * const pvParameters,
UBaseType_t uxPriority,
StackType_t * const puxStackBuffer,
StaticTask_t * const pxTaskBuffer ) /*lint !e971 Unqualified char types are allowed for strings and single characters only. */
TCB_t *pxNewTCB;
TaskHandle_t xReturn;
configASSERT( puxStackBuffer != NULL );
configASSERT( pxTaskBuffer != NULL );
if( ( pxTaskBuffer != NULL ) && ( puxStackBuffer != NULL ) )
/* The memory used for the task's TCB and stack are passed into this
function - use them. */
pxNewTCB = ( TCB_t * ) pxTaskBuffer; /*lint !e740 Unusual cast is ok as the structures are designed to have the same alignment, and the size is checked by an assert. */
The size most certainly is NOT checked by an assert. A compile-time assert is preferable:
_Static_assert( sizeof(StaticTask_t) == sizeof(TCB_t), "StaticTask_t must be same size as TCB_t" );
Or at least a run-time assert would be OK:
configASSERT( sizeof(StaticTask_t) == sizeof(TCB_t) );
Hope this helps someone and can make it into the next rev of FreeRTOS.
