system
(system)
December 21, 2006, 3:27pm
1
nobody wrote on Thursday, December 21, 2006 :
i have probably found a bug in tasks.c:
instead of this line in xTaskCreate():
pxTopOfStack = pxNewTCB->pxStack + ( pxNewTCB->usStackDepth - 1 );
the following line has to be written:
pxTopOfStack = pxNewTCB->pxStack + ( usStackDepth - 1 );
am i right??
system
(system)
December 21, 2006, 3:41pm
2
No -
In prvInitialiseTCBVariables():
pxTCB->usStackDepth = usStackDepth;
Therefore:
and
are the same.
Is your pxNewTCB->usStackDepth varaible getting corrupt?
Step through the code following the assignment to see where the corruption occurs. Sounds like you might have a linker configuration error.
system
(system)
December 21, 2006, 4:26pm
3
"Sounds like you might have a linker configuration error. "
what could I have done wrong at the linker settings?
I use the H8S2398 CPU with 8k RAM
the sections I use are:
.vects 0x00000000
.text 0x00000400
.bss 0x00FFDC00
.stack 0x00FFFBF0
is this wrong?
with the original code it worked for stack sizes until 255, if I use 256
pxNewTCB->usStackDepth gets a value of 0x10000
with my modification it works.
system
(system)
December 26, 2006, 4:45pm
4
imajeff wrote on Tuesday, December 26, 2006 :
I have sometimes noticed where the choice of code seems to fail to optimize for size nor speed. So why (pxNewTCB->usStackDepth - 1) instead of (usStackDepth - 1) When obviously the latter would excecute better? Shoot, is this RTOS, or is this MS?
